Question about honda part number. help plz
Old Nov 26, 2007
jdmhonda1's Avatar
jdmhonda1 is an unknown quantity at this point
Hello everyone. Im new to the forums. Anyway, i drive a '03 honda civic and i recently got a check engine light for the TPS *throttle/pedal position low input*. I'm looking to replace the throttle body and just wanted some assurance that the part i'm ordering is in the correct one needed to fix the problem. http://www.hondaautomotiveparts.com/...Y&vinsrch=null
370468 002 1 BODY ASSY., THROTTLE (GY79A)
is that the correct part? thanks for any input.
Old Nov 26, 2007
greeen01civic4d's Avatar
Re: Question about honda part number. help plz
why wouldnt u replace the tps sensor instead??
Old Nov 26, 2007
because the tps is not sold separately and very hard to change/adjust to spec. if i were you, i would pick up a $50 used TB from ebay. worked wonders when i had the same problem. just clean it up a bit before installing. alot better than being raped by the dealer as im sure new ones go for a few hundred dollars. all throttle bodies are the same for 01-05 civic EXCEPT for auto vs manual trans. be sure you buy one for the correct transmission type or you will not like what happens.
Old Nov 26, 2007
BiH's Avatar
BiH
BiH is an unknown quantity at this point
(370468)... Yes, That's a correct part number.
Old Nov 26, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Thats not a part number, thats a catalog number.
the part number is
16400-PLM-A03
Old Nov 26, 2007
BiH's Avatar
BiH
I stand corrected....
It's a correct catalog number!!!!!!
Old Nov 26, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
If you need I have a spare Throttle body. $50 shipped.\
Its from a D17A1 Manual Trans.
Old Nov 26, 2007
i bow to u, i stand corrected once again Gearbox, thanks for the info
Old Nov 26, 2007
CivicDuty's Avatar
CivicDuty is an unknown quantity at this point
Have you or the dealer gone through the troubleshooting process for the sensor to verify that its actually the sensor and not a broken wire or something?
Old Nov 27, 2007
jdmhonda1's Avatar
no i haven't. i've looked at the sensor but there doesn't seem to be any broken wires or anything. My warranty for the car is already up. I'll check again tommorow. thanks for the all help everyone.
Old Nov 27, 2007
CivicDuty's Avatar
If you don't have it already, download the shop manual. The troubleshoot for the TPS is in section 11-65. The link below should be page 4 of the original thread...scroll down to the download.
Good Luck!
https://www.civicforums.com/forums/7...updated-4.html
usajags84
15
Aug 19, 2015 03:12 AM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Myredjonda
Apr 14, 2015 07:00 PM
Bartkat
20
Feb 19, 2002 01:29 PM
