Auto to Manual done. Car wont start. Need help.
Old Nov 24, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
So we just got done doing all the mechanical portions of this. Everything is in and ready to go. Heres the problem:
-We are running an auto ECU and the auto dash harness, but we are running the manual engine harness. Wehn we go to crank the motor, nothing happens. We pulled the silenoid off from under the steering wheel so we can get the key out, but the car wont crank.
I know there is a wire that we need to ground to make the ECU think that the transmission is in park or neutral, but where is that wire? We need help. asap! Thanks in advance.
Old Nov 24, 2007
spoonEM's Avatar
omgwtfbbq mod.
Re: Auto to Manual done. Car wont start. Need help.
Old Nov 24, 2007
greeen01civic4d's Avatar
really, i think u need a manual ecu, i dont think the auto ecu wont work, but i could be wrong, but then again, why would they make the ecu's different?
Old Nov 24, 2007
spoonEM's Avatar
omgwtfbbq mod.
No...the auto ECU will work. Right now the computer thinks that the car is in drive. So we need to find that wire, and ground it so the computer wont think that and we can crank it over. Its just a pain in the *** finding that wire. I know someone on here HAS to have done this before.
Old Nov 24, 2007
dopes6070's Avatar
ya I know the auto ecu will at least work because we drove the car arround the block after bump starting it.
Old Nov 25, 2007
well, it looks like someone needs to get a hold of honda's electrical manuals, if u havent figured it out by then, ill get online at work and find out if i can get the info ur lookin for, we have mitchell on demand at work, so maybe they will have the info u need, what year is ur car, and what submodel ie lx dx ex vp
Old Nov 25, 2007
spoonEM's Avatar
omgwtfbbq mod.
Well we have the actual honda service manual, and thats not helping out at all. Were going to give it one more shot today and see what we can come up with.
Old Nov 25, 2007
yea, but do u have the electrical manual, or the mechanical manual, there are both
Old Nov 25, 2007
dopes6070's Avatar
no we dont have the electrical manual. I actually talked to rob yesterday about getting one just so we could finish it up.
Its a 2002 Civic LX Sedan
Old Nov 25, 2007
ok, ill check at work tomorrow, its the only place i have access to it, so ill chek on lunch, and see if i can find the park switch wire for ya
Old Nov 25, 2007
spoonEM's Avatar
omgwtfbbq mod.
No need! haha. We got that bitch running like a champ today. We just ended up leaving the auto harness in there and moved the control unit for the gear selector out of the way. thanks to varner88 for the tip!
Old Nov 25, 2007
thats actually a brilliant idea... props to varner
Old Nov 25, 2007
dopes6070's Avatar
alrite finished we ended up using the auto harness with the shifter position sensor still plugged in. Once we did that it fired right up
Old Dec 8, 2007
hcoinvdiac93's Avatar
hcoinvdiac93 is an unknown quantity at this point
the car wont start with a manunal tranny now?......push the clutch pedal in...JFWY I think it is that wire u have to ground for the ecu
BTW i only read like the first 4 post so if u already found the problem, good for u
Old Dec 8, 2007
dopes6070's Avatar
We figured out a way around the problem.
C6GrandSport
Apr 25, 2015 09:41 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
ImmortalEX
Oct 31, 2001 10:00 PM
