Driver side door won't lock or unlock (help)
Old Oct 25, 2007
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
My driver side door won't lock or unlock when i arm the car , but the passages side door can. I went under the hood and check the power door lock fuse and it seem to be fine. Any suggestions what could be the problem?
Old Oct 25, 2007
greeen01civic4d's Avatar
Re: Driver side door won't lock or unlock (help)
door lock actuator, 25 bucks at honda
Old Oct 25, 2007
if u have a two door, part is here, #32 http://www.hondaautomotiveparts.com/...gry5=DOOR+LOCK
or 4 door, again #32
http://www.hondaautomotiveparts.com/...ONT+DOOR+LOCKS
Old Oct 25, 2007
Thanks.. where the part located at? Tomorrow if i have time i can take the door apart and see .
Old Oct 25, 2007
take off the door panel, follow where the inner door handle is located, down the metal bars to the actuator, its yellowish white and will be connected to the metal bars, its quite simple, just pay attention to how it comes apart.... it is also connected to the actual latch mechanism, its quite simple, but time consuming. but i gaurantee that this is ur problem, many of us have had it, including myself
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
maaronia
May 14, 2015 10:46 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
