timing belt fun...
Old Oct 12, 2007
greeen01civic4d's Avatar
timing belt fun...
well, im about half way through the timing belt process, belts came off, alternator off, power steering off, motor mount off, valve cover off...
next step is to loosen the crank pulley, all i can say to me is good friggin luck, wish i had my impact at home, it would be so much easier, but alas, no compressor at home... anyway, gonna try and break free the bolt tomorrow, im out of light at this point, hood closed, tools put away, and wheel back on, still on jack stands....
ps, i got the actual install directions from honda, their parts guy printed em off for me!!! sweet right, if i can find a scanner, ill post em up, cuz they are great, with torque specs and all
Old Oct 14, 2007
DsevenEm2's Avatar
This is Myspace
Re: timing belt fun...
yea thatd be awesome.. good luck with this... u should keep track of what your doing and any mistakes or things we should avoid.. im going to be doing mine soon and id like a little reference of anything i should look out for.. tools i need, things to avoid, what loosen and what not to.... scan those directions thatd be great!
Old Oct 14, 2007
spudz904's Avatar
spudz904 is just really nicespudz904 is just really nicespudz904 is just really nicespudz904 is just really nice
good luck with that. i have to do mine soon......if u post up those instructions that would be awesome
Old Oct 14, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
pulley tool on 1/2" drive socket, get the socket wedged between the axle and the LCA, 5' aluminum jack handle slipped over a breaker bar with a 1/2" drive 19mm socket on it. Take off the bumper and lean on the jack handle.... it'll pop loose.
Old Oct 18, 2007
psmitty7373's Avatar
psmitty7373 is an unknown quantity at this point
Is the crankshaft pulley bolt left or right handed threads?
Old Oct 18, 2007
Alpha 5's Avatar
in for the future.
Old Oct 18, 2007
its left hand
Old Oct 18, 2007
oh, and parts should be here tomorrow
Old Oct 18, 2007
Just to be clear before I do something crazy, its left handed thread. Meaning clockwise rotation removes the bolt.
Old Oct 19, 2007
no, counterclockwise, its a standard bolt, turn it counter clockwise! i just finished mine, completely done, added coolant and everything, started and no problems!!! im so glad to be done finally
Old Nov 6, 2007
Black7Ice's Avatar
Black7Ice will become famous soon enough
When i did my timing belt it was right hand threads, counter-clockwise to loosen.
what i did since i didn't have the fancy crankshaft holder was a 2" nut with a matching 3/4" drive socket and a pipe wrench with the 19mm socket inside the 2" nut and a 1/2" drive extension going out to a T handle and some cheater bars. I'll see if i can get pics up later.
props to getting ahold of the honda tech sheets, i didnt think of that
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
