newbie here......popping noise
Old Aug 23, 2007
02cvcdx's Avatar
02cvcdx is an unknown quantity at this point
i have an 02 civic dx everytime i turn or stop or take off..pretty much all the time im hearing my wheels/axle i dont know what it is "pop" im not real sure what it is any help is appreciated thanks.
Old Aug 23, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: newbie here......popping noise
are the tires rubbing
Old Aug 23, 2007
02cvcdx's Avatar
no, it just a loud POP everytime i change the position of the wheel, for example if im backing out of the driveway and then put it in 1st gear as soon as i let the clutch go and give it gas and the wheels begin to go forward it pops. it sounds as they adjust themselves or something it also does it everytime i make a comlete left or right turn, not much on yields and stuff like that.
Old Aug 24, 2007
PCaly2112's Avatar
PCaly2112 is an unknown quantity at this point
is the car modified at all?
Old Aug 24, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
it's one of your axles or halfshaft. if it's doing it when you take off, your inner CV joint is probably bad. if it does it when you turn, outer CV joint. you're better off buying new axles because newer cars don't really have CV joints that are easily replaced like older cars. you can get lifetime axles/halfshafts at advance or auto zone for just over 100 bucks, without core charge, so make sure you take your old one in.
Old Aug 25, 2007
ESK1k20A2's Avatar
ESK1k20A2 will become famous soon enough
axles maybe hub bearing lift ur car and try to moved the wheels side t side and up and down if they moved wheel bearing
Old Aug 27, 2007
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
It could also be the strut bearing plates. do you have lowering springs or coilovers on stock struts? in 02 honda did put out a TSB on a poping noise comming from the front when turring. it happen to be to thick of paint in the strut tower. as funny as that sounds its true. when turring it made a popping noise. to fix the problem the sruts were to be removed and the exseise sp* paint had to be removed or ground out.
jay
Old Aug 27, 2007
02cvcdx's Avatar
thanks yall i appreciate oh and no i dont have any lowering springs... i plan on getting some though ... what do yall recommend????
Old Aug 27, 2007
YSIDRAG's Avatar
its realy all in how low you want to go and how much money you want to spend.
jay
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
