Air fuel ratio sensor or oxygen sensor?
Old Jul 2, 2007
carewbeats's Avatar
carewbeats is an unknown quantity at this point
Please don't make me run in more circles!!!!
Ok, so I need to replace my 'primary o2 sensor', or at least that's what I'm told. Honda says they'll do it for $500. I say 'screw that'.
I replace primary (before cat.) sensor with Walker OEM part 25024473. I should be good I thought. still throwin codes P0134 and P1164. I do more research and find that there is an air fuel ratio sensor that is 4X the price that maybe is what I need. Is it? What do I need? What's the difference between the two?
here are the two parts:
a/f sensor.....
http://www.carpartswholesale.com/v4/...nsor&catalog=p
o2 sensor.....
http://replacement.autopartswarehous...Sensor&dp=true
PLEASE HELP ME!
Old Jul 3, 2007
andyman97's Avatar
Turbo Guru
Re: Air fuel ratio sensor or oxygen sensor?
What year is your car?
Old Jul 3, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
the Air fuel sensor is a wideband. If you have an HX, or an 04-05, you need the expensive one.
Old Jul 5, 2007
carewbeats's Avatar
Lightbulb Re: Air fuel ratio sensor or oxygen sensor?
It's a 2002. I think I finally figured it out after lots of research.
Nobody seems to know anything about the HX. Apparently the oxygen sensor fits perfectly into the plug that the air/fule ratio sensor goes.
Ordered the 'expensive one', so I should be on my way when it gets here. DAMN!!! If my light's still on after that, you'll be hearing from me again very soon.
Thanks for the help.
Old Jul 5, 2007
andyman97's Avatar
Turbo Guru
Your car is an hx, your primary sensor is an air fuel sensor, not a standard oxygen sensor. You do, in fact, need the "more expensive" sensor. But...you can pick one up from majestic honda for an 04-05 (same sensor) for barely over $100. I just bought one from them.
CarStuff
Dec 6, 2020 12:52 PM
KillerX
Apr 9, 2017 08:20 AM
juror
May 26, 2015 06:35 PM
bsmiley
Apr 27, 2015 01:27 PM
Booohahaha
Jan 20, 2002 12:03 PM
