Solution -Grinding noise while acclerating in 1st and 2nd gear
Old Jun 11, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
I went to my neighbourhood Honda for an Oil change and regular stuff. Mentioned about my problem which is similar to some other members here that have mentioned it. Funny grinding kind of noise in 1st and 2nd gear while accelerating.
I took one of the mechanics with me for a test drive so that they could understand what i meant. And within the first few seconds the guy caught it and gave me this solution.
Replace Main Shaft Bearing, It seems to be worn out. Part costs under $20 and u have to get a lubricant which is also under$20. But Labor... NO COMMENTS
Sigh ... Now lets see if it works .. Im gonna look for a private mechanic to do it though ...
Old May 5, 2009
evolutionmr's Avatar
evolutionmr is an unknown quantity at this point
Re: Solution -Grinding noise while acclerating in 1st and 2nd gear
i'm having the exact same problem you described...let me know if this works...if so i will go and get it done as well
Old Jun 2, 2009
breault5's Avatar
breault5 is an unknown quantity at this point
yeah is it like a noise thats similar to the sound of putting a baseball card in your spokes on your bike when you were a kid.? kinda liek a thudding noise?...
when you put your clutch in does the noise stop??
Old Jun 2, 2009
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
is this for auto or mannys?
Old Jun 14, 2009
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
There's a sticky at the top of Mechanical Problems/Vehicle Issues and Fix-it Forum called DIY: Diagnose manual Tranny Noises (and save some $$$). My car has this problem. It was diagnosed at 100k miles, july 2006. I'm at 160k with not fixing it and the car runs the same. Just more noise when the clutch is up.
The Honda dealer wanted $1700 to fix the main shaft bearing and install a new clutch.
rayman7
Jun 20, 2015 09:48 PM
Blazz
Jun 4, 2015 01:04 AM
blaketippett
May 29, 2015 08:02 AM
cruisers10
May 12, 2015 10:46 PM
markp94
Apr 30, 2015 09:19 PM
