91 accord - how would oil end up in distributor cap?
Old Apr 10, 2007
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
wasnt able to start this thing for a month. today deicded to start taking it apart to see if i can find anything wrong. found a bunch of oil in the distributor cap, cleaned it out. car started right up
now my question...howd it end up there?
Old Apr 10, 2007
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Re: 91 accord - how would oil end up in distributor cap?
If your distributor is right on the camshaft then the oil seal in front of the distributor is gone bad.
Can not tell exactly how u can do it easily. You may be just grab it with a pair of needle nose pliers and pull it out.
worse comes to worse - you got to take ur camshaft out. (get the tightening pattern when u put it back together and u may also have to do valve clearance since the camshaft is pulled out)
Wild Cranker
427
Jan 28, 2016 06:49 PM
RIPSAW
Nov 6, 2015 04:36 AM
dpru
May 26, 2015 07:01 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
supercivic01
South
Nov 30, 2001 11:27 AM
