Rear View Mirror Mod
Old Apr 1, 2007
daviddittmer's Avatar
daviddittmer is an unknown quantity at this point
I need to either replace or modify my rear view mirror. My problem is that the stock mirror is mounted a little bit too low, and since I'm 6 feet tall it directly blocks my view. I'd like to mount it up higher, closer to the roof, to get it out of the way. Any suggestions? I have an '05 coupe.
Thanks
~Dave
Old Apr 1, 2007
TRIZ's Avatar
Re: Rear View Mirror Mod
dremel and epoxy.
Old Apr 1, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
rip it off and move it.
Old Apr 1, 2007
TRIZ's Avatar
...Hmm, in my 01 they are screwd into the roof wit four screws... are the later modles stuck to the windshielf with adhesive?
Old Apr 1, 2007
yea and the adhesive is permanent from what ive heard. you will break the glass trying to remove it.
Old Apr 1, 2007
my 05 is screwed to the roof. dont know about a solution for that that will look good.
Old Apr 1, 2007
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
The later models rear view mirrors are also mounted to the roof with four screws. You can buy an aftermarket one and mount it to the windshield with the adhesive stuff (just mount it a little higher). The adhesive stuff is pretty damn strong. I used that stuff when I mounted my gentex temp/compass mirror and i haven't had a problem
Old Apr 1, 2007
Mine is mounted to the roof. Removing it and then attaching a new mirror to the windshield with adhesive sounds fairly easy. Should I go with that solution?
~Dave
Old Apr 1, 2007
yeah if it comes off and looks okay without a big hole in the roof. the adhesive is special and you can get from any auto parts store.
Old Apr 1, 2007
buckshizzo's Avatar
The only problem with that is that once you mount a mirror on the windshield, you'll have an empty spot on the roof where your old mirror was attached. The cap that covers the screws and stuff is actually attached to the original mirror. What I did was dremel off the shaft that was attached to the original mirror and kept the metal piece with the screws and screwed it back in.
Old Apr 1, 2007
Great idea. I'll probably do the same. What mirror did you install; anything special?
Old Apr 1, 2007
buckshizzo's Avatar
yeah I installed a gentex mirror that has a temperature and compass. I got it off an 04 chevy tahoe. Looks pretty cool and I kinda like knowing what the temperature is.
Old Apr 2, 2007
nice you could get the 06 civic one too that has auto tilt and some electronic stuff lol
Old Apr 2, 2007
buckshizzo's Avatar
yeah I thought about getting the '06, but it didn't have a temp display. Besides my good friend ebay had it for way cheaper. I paid about $100 for the mirror, wires and sensors.
GotSiR
Jun 23, 2016 04:06 PM
Misfit2613
Jul 30, 2015 09:49 AM
jessicanicole
Jul 23, 2015 09:14 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
igorbogu
Jul 10, 2015 09:29 PM
