question about stock intake
Old Mar 28, 2007
itchoy's Avatar
itchoy will become famous soon enough
Smile question about stock intake
in the intake assembly there are 2 parts...the one that has no filter an the one with filter(i think)....so is it ok if i get the one that has no intake?
took it off...it sounds good
Old Mar 29, 2007
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Re: question about stock intake
i think you took out the resonator assembly out looking at ur pirtures and what u said. i think its just to keep the noise down.
Old Mar 29, 2007
itchoy's Avatar
oh...tnx for your comment
Old Mar 29, 2007
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
is that all that part of the intake does? It just keeps the noise down?
Old Mar 30, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
https://www.civicforums.com/forums/7...nator-box.html
Old Apr 3, 2007
JeesunUltra's Avatar
JeesunUltra is an unknown quantity at this point
crack it open, you'll see tubes branching out from the main tube to the hollow part of the box. the hollow part of the box acts as a reservoir of air. when you start to accelerate, it lessens the time of the throttle body to suck air.
Old Apr 3, 2007
wheelspinLX's Avatar
wheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nicewheelspinLX is just really nice
Without the resonator my car has a humongous reservoir of air called the atmosphere to suck from right next the the throttle body...
Old Apr 4, 2007
^ lol. youre right.
ok lets put it this way. the resonator "gathers" and "composes" the air then hand it over to the filter then to the throttle body. like a servant who picks and stems out a grape and put it in her king's mouth.
its always easier to eat something that is already prepared than preparing your food by yourself.
removing the resonator and leaving only the filter box is like having a short ram intake. we all know (most of us do) that it only helps to produce power at high speed where it helps to circulate the air in the engine bay. other way goes for the cold air intake.
im going little off here. the resonator gives the throttle body an instant heat-insulated air for suction thus giving you power in taking off (0-40kph or 0-20mph)
Old Apr 4, 2007
btw, looking at the picture above... the throttle body would be sucking hot air. evrey rise in the air temperature causes the engine to lose about 0.1hp
why do you even need a noisy engine bay if youre running on stock?
Old Apr 4, 2007
ashokudu's Avatar
I still can not see that the resonator acting as a reservoir.The branching tubes that u see are cavities, each cavity is used to decrease noise created by one frequency (attenuation). Thats the reason its called a resonator.
Old Apr 4, 2007
there are several functions of the resonator, not just to keep the noise down.
heres a few i know so far:
- intake tube is near the fender wall away from the engine to avoid sucking hot air.
- helps to block heat away from the air passage
- keeps the vacum noise down
- acts like a resevoir of air for instant acceleration (as far as i know)
Old Apr 6, 2007
DsevenEm2's Avatar
This is Myspace
and thats definately gonna hurt out d17s. he's doomed....
carid
Apr 30, 2015 07:00 AM
cloudguy
Apr 28, 2015 05:02 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
viper775
Nov 8, 2001 09:14 PM
