2001 problem with door lock/tumbler mechanism
Old Mar 20, 2007
Intercooler's Avatar
Intercooler is an unknown quantity at this point
Angry 2001 problem with door lock/tumbler mechanism
The other day my doors were iced up real bad so I don't know if this is a result of me pounding on them or whether someone tried to break into my car. Maybe someone here can help me determine? At any rate I need to fix it now!
What I found this morning was the lock piece where you put your key in to open the door (tumbler) sitting back in the door about 1". I could still get the key in it but it just wobbles and I can use it to open or lock the door because it isn't stationary enough. I don't know what in there could have broken but I am trying to find the right part to order. Looking at this drawing does anyone have an idea what could have broke:
http://www.hondaautomotivepart...+LOCK
I don't see anything like someone took a screwdriver to it or hit it so I have no idea how this happened. Maybe tugging on the door when I had ice??
#10 ..... Is that a clip that maybe holds the tumbler/lock in place? Maybe it fell off?
I assume I have to take the entire door apart to get at this?
Old Mar 22, 2007
20civic01's Avatar
20civic01 is an unknown quantity at this point
Re: 2001 problem with door lock/tumbler mechanism
i had the same problem as you. i think mine was a result of the multiple break-ins on my passenger side, but for a while, the lock was recessed about an inch, and then once when it was iced up, the lock fell out. the guy at the dealership said the clip falls out a lot, but when i opened up my door, i was able to stuck the tumbler back in the hole, and it's fine. you should be able to take the door panel off yourself and just stick it back in the hole. if the clip fell out, it's probably in the door frame somewhere still, so you probably don't even need to order anything. if it's more serious than that...i dunno. good luck
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
supercivic01
South
Nov 30, 2001 11:27 AM
