Help with installing AEM short ram
Old Jan 12, 2007
TrAvIs 05's Avatar
TrAvIs 05 is an unknown quantity at this point
It comes with two big rubber pieces one is like normal size and the other the one opening is smaller than the other side. Which one do i put in between the two intake pieces (longer pipe and "J" pipe)? Also, it looks like the AIT sensor doesnt reach whats up with that and how do i fix it? Also, there is a kink in the rubber tube that connects to the valve cover is that normal?
Old Jan 12, 2007
TrAvIs 05's Avatar
Never mind... i got it.
Old Jan 12, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
If I remember correctly, "normal" fitting goes on TB/1st pipe, other fitting goes between pipes with larger opening toward filter (look HERE some pics are similar to SRI). Just see how they fit together. My sensor is tight but it fits. Kink shouldn't be an issue, it will straighten out with time. Just make sure it isn't cracked, or replace the hose.
Old Jan 12, 2007
bobsagator's Avatar
You're not supposed to figure it out while I'm typing...lol.
cukaracha
May 16, 2015 07:36 PM
ModNewbieHELPME
Nov 20, 2001 12:25 AM
HuDaThaN
Bolt-on Engine Performance
Nov 18, 2001 09:27 PM
clownprince
Nov 15, 2001 01:37 PM
onelifetolive
Nov 10, 2001 10:58 AM
