Steering vibration
Old Dec 20, 2006
eggfooyoung's Avatar
eggfooyoung is an unknown quantity at this point
Steering vibration
Hi everyone. I've got a really weird problem. When i'm on the highway doing about 100km/h my steering wheel starts to shake/vibrate. This started happening a little while ago when I got my brakes done at the dealership. I had the rotors turned and new pads put in. It just started getting a little worse now that I got an alignment done. Does anybody know what could be causing this?
Hey guys. Just got the car back from the dealer. The tires needed balancing. The belt inside the front tires shifted so that was what causing the shaking. They rotated the front tires to the back and used weights to balance them out. Car is back to normal. Thanks guys for giving me your opinions on what was wrong with my car. I guess now I'm going to need new tires.
Old Dec 20, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Have your alignment checked, and wheels balanced.
Old Dec 20, 2006
Kajus's Avatar
Kajus is an unknown quantity at this point
Your alignment wont cause your steering wheel to shake.
Get your rims/tires balanced.
Last edited by Kajus; Dec 20, 2006 at 08:06 PM. Reason: add rims so people wouldnt get confused "get my tire balanced!?"
Old Dec 20, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
are you kidding? if your caster is off and your wheels are turned in, your steering wheel will shake...
check your rotors to make sure theyre not warped, then balance the wheels, if that doesnt fix it you got a shitty alignment...
Old Dec 20, 2006
Kajus's Avatar
your caster will just make you get horrible treadwear, its not gonna make the steering wheel wobbel, here google's it.
http://www.faqfarm.com/Q/Why_would_t...g_wheel_wobble
http://www.faqfarm.com/Q/What_causes...steering_wheel
Wheel Alignment or Front end Alignment will not cause a vibration.
2nd link above the CV joint bullet
Old Dec 20, 2006
Ban!
Old Dec 20, 2006
no really i think your rotors are warped
Old Dec 20, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
hrmm yes your alignment can cause your steering wheel to shake/wobble. i know b.c our mini van hadnt had an alignment done in a long *** time and if i were to go over 60mph it would shake real bad.
my suggestion:
1) check alignment again
2) balance wheel if not already
3) if u have larger than stock wheels and the hub isnt sitting flush against the brake hub(w.e u call it on the car) get hubcentric rings
4) take it bak to the dealership and complain
Old Dec 20, 2006
Kajus's Avatar
omfg!!! go to a suspension shop if you dont beleive me
i only gave you links to sites that give you all the info you need!!! wheres boilmaker when you need him
Old Dec 20, 2006
my suggestion:
Thank You..
Zack...
Old Dec 20, 2006
Kajus's Avatar
Alignment wont cause a vibration... It will cause your car to pull, wear tires quickly/uneven and maybe handle poorly but it WILL NOT cause a vibration.
adam you suck @ aim
/waits for boilmaker1
Old Dec 20, 2006
crazyasian's Avatar
.......w.e. just cant thro to some hard headed people. yes a bad alignment will cause your car to pull if not done right. but if it was done really bad or havent been done in a long time, such as our mini van, it can cause vibration at high speeds.
Old Dec 20, 2006
Kajus's Avatar
bad tires/unbalanced, omfg go to a suspension shop right now or tomorrow and ask. or just wiat for boilmaker1 or google yourself and learn something.
this site = down hill with all this stupidity
And since when is knowing actually causes something being "hard headed"
Why don't you get some hard evidence of the alignment making the steering wheel wobble instead of saying "well on my mini van this my mini van that" ? hmm ive posted my info it's there and im sure others will agree with mine
Old Dec 20, 2006
yeh hes right...just needs a balance...
maybe only in the most severe case of a terrible terrible alignment might it cause steering wheel shake...but i bet its the rotors
Old Dec 20, 2006
crazyasian's Avatar
hrmm u havin fun trying to prove your point across? i truly dont care. my advice was given and so was my personal expierence. boilermaker can also come in here and tell me im wrong but i still wont care b.c its his 2 cents and there is no reason for me to go off on it. all i know is that i feel that much better that i helped someone to get their problem solved, thats all.
Old Dec 20, 2006
Kajus's Avatar
I'm sorry if i offended you but i like to give people the right answer not the wrong one.
blame boost_junkie for me getting frustrated *** kept aiming me trying make me mad
cuase my car > his
hahaa
Old Dec 20, 2006
keep it in your pants Zack...you know you love it
Old Dec 20, 2006
chinaman's Avatar
chinaman is an unknown quantity at this point
Wow, you guys are really goin at it.
I'm goin to agree with the crazy asian dude about the alignment deal. If your toe is misadjusted you could get a vibration. For instance if your vehicle has too much positive toe, the tires will be pointed inward which will casue the tires to fight against eachother. Same for too much neg. toe. FWD vehicle tend to toe-in while driving. Only in extreme cases will warped rotors cause a vibration. So i'm goin to disagree with the warped rotors causing the vibration. But in this case is sound like it's just a tire/wheel balance issuse.
Old Dec 21, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
I had steering wheel shake a few months ago. Got a good alignment and it went away.
Old Dec 29, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
They probably balanced your tires while they were at it.... If you're getting shaking at high speed, it is more than likely your tires being off balance. Your rotors being warped will NOT cause shaking unless you're applying your brakes. Your alignment will NOT cause your vehicle to shake at high speed. Alignment fixes your steering and tire wear.
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
