Questions on engine noises and maintenance of 2005 Civic VP Sedan
Old Sep 29, 2006
capriblu's Avatar
capriblu is an unknown quantity at this point
Hello everyone,
happy to be onboard! I have a few questions on a 2005 Civic Value Package Sedan I bought last year:
1) The manual calls for 5W-20 engine oil every 10,000 miles. Should I stikc to this type of oil and oil change interval if I want to run the car for a long period of time (over 200,000 miles)?
2) The manual also says that AT fluid and filter, spark plugs and coolant don't have to be changed until 110,000 miles. Is this recommendable? If not, what are the recommended intervals.
3) There are two noises I have noticed. One is a high pitched, faint whining noise that goes with the revs that has been there from day one. The dealer says it is normal. Is this true?
4) The other is a dull tapping noise. I have not adressed this yet at the dealer. Could this be the engine mounts?
Thanks for your help!
Old Sep 29, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
Originally Posted by capriblu
Hello everyone,
change your oil at 3k miles.. i dont care what the manufacturer says, 3k miles... it's not the car that decides the oil life, it's the oil... i made the mistake of waiting 5k miles on my subaru that recomends 7500 miles and the motor blew due to friction in the rod bearings... and since i didnt' use "subaru oil" and mainly because i didn't have it serviced there, they blame it on me and i'm stuck building a new motor right now..
Old Sep 29, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
Alright First Things First I Work For Honda Parts And Service, Change Your Oil Every 3-5k, I Change Mine Every 3k With Amsoil Synthetic
Change Your Brake Fluid And Transfluid (clutch Fluid I/a) Every 30k
Rotate Tire Every 10k Unless You Like To Abuse Your Front Tires
T-belt At 100k
Do Plugs At 50k
Old Sep 29, 2006
Wadely's Avatar
As Far As The Noises, They Are Hard To Adress Through A Website, Unless You Got Audio Clips Lol.
I Know When I Got My Pigdar Going My Car Will Make A High Pitch Whistle At About 3 Grand And Stop When I Shift And Start Again In The Next Gear At 3 Grand
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
smmahan
Apr 15, 2015 08:17 PM
dano2005
Apr 14, 2015 01:58 AM
