Engine cuts out in civic
Old Dec 20, 2006
oldmixon's Avatar
oldmixon is an unknown quantity at this point
I have a 2004 civic EX manual transmission. On the way into work this morning, every few minutes or so i would hear a clicking noise coming from under neath the glove box area and the engine would cut out for a split second and come back without stalling, but causing some bucking. The tac drops to 0 and the check engine light comes on, then goes off when the engine comes back to life. Also, my maintenance required light has been on and it will not go off from following the instructions in the manual. Any idea whats going on?
Old Dec 20, 2006
landonab
Guest
Posts: n/a
Sounds like you may have a wire going to ground. Have you checked all of the wires going through the firewall below the glove box? Does it do this while in idle also?
Old Dec 20, 2006
oldmixon's Avatar
actually, it does. When i got to work, i sat there for a few minutes in the parking lot and it would do it every minute or so.
weird this is this happened about a year ago on one drive and never happened again. i had brought it into the dealership and they said they couldnt do anything because ut wouldnt happen for them.
Old Jan 4, 2007
7th wonder's Avatar
7th wonder is an unknown quantity at this point
im not very well versed in honda technical studies but it sounds like a fuel pump relay. if there is even one on these cars.
Old Jan 4, 2007
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
have you replaced your battery or touched any ground wires or wires connected to the battery. I say this because I had this same thing happen to me because I forgot to completely tighten the battery terminals. Also, is there acid build up on the battery terminals because they may need to be cleaned. Very weird and interesting things happen when ground wires and battery terminal wires dont have proper contact.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Fastfebur
Apr 22, 2015 01:37 PM
doublins
Nov 11, 2001 07:01 PM
spoony
Nov 7, 2001 11:01 AM
