**** zip ties
Old Dec 11, 2006
charcoalex's Avatar
charcoalex is an unknown quantity at this point
**** zip ties
when i put my suspension on a while ago it didnt come with brake hose brackets to hold the brake hose so i zip tied them to hold them in place and my wonderful tires wore a whole through my brake hose and now i have no brakes.
Old Dec 11, 2006
wow.. that sucks.. it didnt have a place to bolt the brake lines to? when i did my suspension, i just used the stock brackets and bolted them up to the suspension as if it were stock... what kinda suspension you running?
Old Dec 11, 2006
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Damn thats a stroke of bad luck.
Next time you should have the foresight to think of maybe zip them in a manner that holds them securely away from any moving parts.
Old Dec 11, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
guess you might as well upgrade to stainless steel brake lines now for that firmer pedal feel
Old Dec 11, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
^i was thinking the same thing...might as well since they gotta be replaced
Old Dec 11, 2006
Boggie1688's Avatar
Diamond Member
Mm...steel brake lines...I think you can get a set for rougly 100 bucks.
Old Dec 11, 2006
tsudocivic2k4's Avatar
tsudocivic2k4 can only hope to improve
tough luck man! YIKEZ
Old Jan 10, 2007
charcoalex's Avatar
ya they are like 100 bucks. im running ksports right now. the only one my buddy put on was the front right and he broke the tie bar so i didnt think about zip tieing them securly i had to get it to the shop to replace it cuz i had to get an alignment too. brakes. suck.
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Blazz
Aug 30, 2015 11:07 PM
17
Jul 23, 2015 11:48 PM
