Removing side air vents?
Old Jan 8, 2007
k-man's Avatar
k-man is an unknown quantity at this point
I need to remove both of the side air vents in the interior of my civic coupe but I have no clue how to proceed. Do they just pop out? does anyone know how they come out?
thanks
Old Jan 9, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
From what I remember, push vent all the way up or down, then grab exposed vent area and pull out. Some people have used a screwdriver wrapped in cloth, but I'm pretty sure it just pulls out.
Old Jan 9, 2007
bobsagator's Avatar
There are 4 clips, one at each corner on the sides. Push vent all the way down, grab bottom of vent housing, and pull out.
Old Jan 9, 2007
k-man's Avatar
awesome, thanks alot for the help. Do they come out and re-install faily easy? I wont mess around if it will cause me a hastle.
also, im not sure if you know this but, I am planning on switching out the portion of the vent that swivels with the US part as the SE console I bought is US spec and has the chrome ***** on the vents(in Canada they are black plastic), so i want to match the side vents.
Is it easy to separate this part from the vent housing and re-install? as it is possible to purchase just that part of the vent or the entire vent assembly as a whole (which is obviously more expensive).
thanks
Old Jan 10, 2007
bobsagator's Avatar
I pulled my driver's side out one time to determine how to get it to stop swiveling so easily and put it back in. No problems, just don't break the clips that hold it in.
I believe the vent just pops out of the housing. All my vents are completely black, I've never seen any with silver *****. The vent should be able to be purchased separately like at Majuestic. Have you thought about just painting the ***** to match?
Old Jan 10, 2007
k-man's Avatar
thanks again...the silver/chrome ***** started 03 or 04+ i beleive
i found the price, its $5 each for the vents, might as well replace as opposed to painting..
Old Jan 10, 2007
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
where did you get that price from, honda?
Old Jan 11, 2007
bobsagator's Avatar
Just FYI - if you order them from Majestic there will be shipping charges and a $5 handling fee. Check your Honda dealership, they'll probably end up cheaper.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Blazz
May 25, 2015 10:56 PM
jc33312
May 12, 2015 03:17 PM
crowtoo
May 11, 2015 06:50 PM
Microbiology
Nov 9, 2001 10:10 PM
