Squeak Squeak coming from the rear passenger
Old Nov 18, 2006
nunzio42's Avatar
nunzio42 is an unknown quantity at this point
Sort-a Sounds like a little mouse is talking to me from my rear passenger wheel well when driving....it doesnt happen all that much but when it does its annoying as $hit.....
any clues? is it a cv joint?
Just as a point of reference i have a 2003 civic 2dr with about 45k on it?!?!?!
Also i have a airbag sensor on....i found the forum thread on how to turn it off and did that but it just turned back on after about a week....is there a diagram where the srs sensors are so i can double check them and make sure they are all connected?!?!? Thanks for any help!
~P
Old Nov 18, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
I had the same problem with the srs light, if you dont do it prefect the light will come back on. Mine usually came back on between 1 to 5 days.
As for the squeaking, it could be your camber kit, if you have one.
Old Nov 19, 2006
nunzio42's Avatar
na no mods to the suspension of the car.......hmmmm
Old Nov 19, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
Its a bushing, bounce it and find out which bushing it is. Then replace it. You might have to chisel them out. Sqeaks come from two pieces rubbing together, so it has to move to make the sound. Just rule out the problem
Old Nov 19, 2006
greeen01civic4d's Avatar
def not a cv joint in the rear, doesnt have em in the rear, also could be a blown strut, they get noisy when blown, thats the problem i think i am having
Old Nov 20, 2006
also check the tsb for this problem, its listed in plasmagt's tsb page page 7 of the tsb sticky listed in this forum, its an easy fix, just a bushing
ghondavic
Transmission
Apr 12, 2017 09:37 PM
superstanko
Apr 28, 2015 04:38 AM
Sparty
Nov 15, 2001 04:55 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
