Shifting Problem
Old Nov 12, 2006
Kung's Avatar
Kung is an unknown quantity at this point
Shifting Problem
Recently there is play in my shifter. When in any gear it feels like I can move the entire shiftbox. For example, I can put it in first and push up a little then when I put it in second I can pull down a bit. It's kind of hard to explain. Also, it seems that I cant shift into 3rd quickly at higher RPMs, it misses the gear and stays in neutral. My friend seems to think it's my clutch, but I have my doubts that the problem is that simple. Going to do some further inspection/diagnoses later, but I'm just wondering if anyone had the same problem before.
2k1 Civic w/ 60k
MT
Old Nov 12, 2006
03EM2_EX's Avatar
03EM2_EX is an unknown quantity at this point
dude the trannys for 01-03 em2 r gay i bought mine from the dealership and the guy said they replace the tranny but 3 months later it was hard to go into reverse and also in 1st and the main shaft/gear whatever got mess up but i still had warrenty new one 4 free. but the trannys for 04-05 are really good compare to 01-03
Old Nov 12, 2006
Kung's Avatar
UPDATE on shifting problems
After driving around today I couldn't put my car into 1st, 3rd or 5th gear. Luckily I was close to home and able to make it back in 2nd and 4th. When I got home I tried to put it in reverse and heard a metal breaking sound (uhh ohh).
Well I removed my center console and come to find out my REVO SS broke! The bracket that is welded to the shifter stick that holds the primary cable just completly broke off! After further inspection (and comparison with the stock shifter) I noticed that the weld for the bracket is not as strong as on the stock. The weld isn't all the way around the bracket. After many years of hard shiftting, the bracket broke from the rear where it wraps around the stick shifter.
Needless to say the weld on the REVO SS is incomplete, and if you are the type that shifts hard (slams it into gear), you might want to keep an eye on this. I'm going to have the bracket welded back on, but this time I'm going to have extra metal and welds that go all the way around the bracket so it never breaks off again!. I would suggest everyone with a REVO SS do this. I've had the REVO SS since it first came out so it has been installed and in perfect working condition for about 4+ years. Anyhow, I would suggest taking your center console off every 6months or so to check that the bracket that holds the primary cable link isn't starting to break off.
I'm glad I kept my stock shifter or else my car would be undriveable right now.
Old Nov 13, 2006
D17master081's Avatar
D17master081 is an unknown quantity at this point
get a B & M you'lll thank me for tellin you taht.....they are a lil more expensive but worth it in th long run
Old Nov 13, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
I'd like to see a pic of this. From what I remember, everything was plastic except the stick itself...
Old Nov 13, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ hmm, thats odd... most people havent had any problems with their revo's
Old Nov 15, 2006
Kung's Avatar
That's because most people haven't owned their revo's for around 4 years. I'm posting up some pics in a few.
EDIT: Pic Links to broken REVO SS. I'm linking them because the pics are large. Remember this happened after around 4 years of shifting. Before the break, the REVO SS worked perfectly and I still reccommend the product.
Broken Bracket
Bracket Break Point
Bracket Break Point Again
Welds Only On One Side
Old Nov 15, 2006
bobsagator's Avatar
Holy giant pictures Batman. I've never seen/heard of that. I'll definately have to check mine soon.
Old Nov 15, 2006
lumina5201's Avatar
lumina5201 is an unknown quantity at this point
has any1 ever had problems with the b&m ss? is there any difference between the b&m and revo, besides the fact that the revo breaks when slammed?
Old Nov 15, 2006
bobsagator's Avatar
B&M is an adapter to your stock stick, Revo is a full replacement. Not all Revo SS break when slammed.
Old Nov 15, 2006
Kung's Avatar
Wasn't from slamming it. Just normal wear and tear. If you look where the welds are in that picture of the welds, you'll see that the welds are only on one side. I say it's from normal wear and tear because it lasted so damn long. If it were going to break from slamming, then it would have broken a lot sooner. Of course if you seriously granny shift all your life, then the revo will probably never break, but why did you buy a short shifter then? =P
Old Nov 15, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
i slam my revo a lot and its working pretty good for me.
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
usajags84
May 30, 2015 06:49 PM
cruisers10
May 12, 2015 10:46 PM
Marcus2thextrem
May 10, 2015 03:08 PM
