Driver Door power lock problem ***
Old Oct 25, 2006
dru's Avatar
dru
dru is an unknown quantity at this point
if car is turned off parked, i hit the lock button once i close the door and the lights flash like they usually do but the DRIVER door will not lock. so i have to MANUALLY lock the door with my key then hit the door lock so the alarm will arm. (factory alarm keyless entry) .... ive tried searching the forums for the answer but i couldn't find the answer.
so to sum it up. all the doors will lock but the driver side door with keyless entry remote button pushed to lock all doors...... same with unlocking...
could it be a fuse under the hood? any info will help! thanks guys!
dru
(2003 honda civic ex coupe)
Old Oct 25, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
a fuse would kill all the locks
sounds like the actuator in yer drivers side door has pooped out on you...
Old Oct 25, 2006
dru's Avatar
dru
can you please try to *guesstimate* how much this will cost to replace.
Old Oct 25, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
well dont assume that parts are broken, get it checked out... its probably the actuator but it could be a ground or something. Just get it checked out first.
No clue about the cost..sorry dude
Old Oct 26, 2006
streetglower's Avatar
the part is only about $17. but if you can figure out how to remove the actuator from the door lock, then please let me know. I ended up replacing the whole door lock assembly. Was only $45 from majestic honda.
www.hondaautomotiveparts.com
But yea you have a bad actuator.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
SSMatey
Apr 13, 2015 06:09 PM
ademarco6
Exterior
Nov 15, 2001 09:36 PM
