2k1 Civic Aircon Foul Odor
Old Mar 17, 2002
Revmaster's Avatar
Revmaster is an unknown quantity at this point
Do you experience having foul odor coming out from your A/C just after you turn on the blower? The odor (smells like wet carpet) suddenly vanish once you turn on the A/C switch. Are there any remedies to prevent this? Thanks.
Old Mar 17, 2002
djlunatic's Avatar
djlunatic is an unknown quantity at this point
its been discussed. the stink is a honda thing. run your a/c more regularly to prevent the smell. it's a mildew that builds up in the vents. worst case senerio take it to your dealer and have him check you a/c and filters. after a minute or so of your a/c running the funk goes away.
Old Mar 17, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i havent noticed anything like that in mine, but ive only had the a/c on once or twice
Old Mar 18, 2002
insan's Avatar
insan is an unknown quantity at this point
i had the same problem, but it went away after a week
Old Mar 18, 2002
iamboo's Avatar
Retired - SoCal FI Mod
mildew buildup on the vents or the filters ? if it's the vents just clean your vents... if it's the filter then WTF !
Old Mar 19, 2002
anibal's Avatar
anibal is an unknown quantity at this point
I have the same problem....I'm thinking it should be the filtration system of the A/C but not sure yet....
Old Apr 1, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
it is mildew that builds up somewhere along the AC lines...my tech told me a quick fix that i havent tried yet
run the AC full blast with it ventign air only inside the car...take soem lysol and spray alot of it inside so it circulates aroudn the ac system..somethign to kill the mildew and leave it on.. otherwise ull have to take it honda have them take apart ur AC system put it in detergent and take a whole day....theyll usually do it once for free
Old Apr 4, 2002
mikepride's Avatar
mikepride is an unknown quantity at this point
I have the same problem it bother my girlfriend more than me.
Old Apr 18, 2002
MyOtherRideIsBritney's Avatar
MyOtherRideIsBritney is an unknown quantity at this point
Exact same problem here, almost from day 1. It seems weird, but the problem really DOES go away right after you turn the AC button on.
I'm a Slave 4 U
808specifxz
Sep 5, 2003 12:57 PM
locozoko
Apr 6, 2002 09:00 PM
slammed2k1civ
Nov 6, 2001 11:52 PM
silvervtec01
Nov 4, 2001 06:56 PM
