3rd Gear Scrapes Please Help
Old Oct 24, 2006
EG06KRS's Avatar
EG06KRS is an unknown quantity at this point
I have a 2001 Honda Civic EX 5 spd. When shifting into 3rd at a high rate of rmps, my car scrapes. Also if I was coming onto an off ramp and shifting into third it scrapes, and under normal driving conditions it scrapes going into 5th. Could skipping gears could have caused this, or is my cluth going out? Thank You and if there was a post about this, I am sorry I did search before I wrote this. Sorry guys, after looking through the different topics I found some of my answer.http://www.7thgencivic.com/forums/im...lies/smile.gif
Old Oct 26, 2006
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Well, hopefully you found your answer. If not, slamming into 3rd will cause your synchros to grind. The more you do it, the worse it gets until you detroy the synchros. If it grinds going into 5th regularly, try changing the tranny fluid. My 01 EX was getting tough going into 5th, changed the fluid and it goes in much easier.
Old Oct 26, 2006
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
ya i was going to say change your tranny fluid, clutch might be going out, i didnt know the vics had synchros on the tranny, if they do thats awesome and it could be those going out.
Old Oct 26, 2006
SOHC_VTEC_pwr's Avatar
SOHC_VTEC_pwr is an unknown quantity at this point
changing your fluid wouldnt hurt and you'd know if you have any damage by looking for metal or bronze shavings. If you find them then you will need to take it apart and find out whats worn. Its more than likely you blocking rings for the syncros.
Old Oct 26, 2006
getsome's Avatar
getsome is an unknown quantity at this point
Yea this happend to my 05 Civic. 3rd synch went out, they said its common in the 04-05's.
Old Oct 31, 2006
HotShotMedic's Avatar
HotShotMedic is an unknown quantity at this point
^ whats common? the 3rd sync going out or any of them going out?
05 civic se
Old Oct 31, 2006
getsome's Avatar
the 3rd and 4th sync for some reason.
Whitexj
Sep 30, 2015 02:04 AM
winanthony94
Sep 25, 2015 09:05 AM
beanhead
Sep 24, 2015 12:04 PM
BBrosario
Sep 17, 2015 07:51 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
