Car stalled...why??
Old Sep 30, 2006
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
Car stalled...why??
2002 automatic
left the car running, stepped out (car was in D with parking brake on) for 3 mins. come back in and see everything is still on (lights/radio) but the car was off. Started back up a1 no problems. I thought it mighta been the air filter cuz it was pretty dirty, so I cleaned it...but anyone know what the problem mighta been?
Old Sep 30, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
my guess is habbit... and without realizing it you figured that leaving the car in drive with the brake on is a stupid thing to do so you turned it off...
if you wanna argue that you didnt turn it off... then well.. yer an idiot and i hope yer car is broken forever... i dont need your stupidity killing anyone i know...
Old Sep 30, 2006
2k4coupe's Avatar
2k4coupe is an unknown quantity at this point
why would you leave the car in d and put the parking brake!!
Old Sep 30, 2006
psst what else would you do, put it in park? right.
Old Sep 30, 2006
karizzle's Avatar
Pinkslip Racer
whats the worst that can happen with putting the parking brake on with the car still in D?? i do it about 150 times a night...(and im not joking either..) ??
btw...ive been doing this for the past 2 months...thats about 9000 times ive done it and still havent noticed anything different...
Old Sep 30, 2006
well once the parking brake cable gets loose enough, the car can start driving away. have fun
Old Sep 30, 2006
karizzle's Avatar
Pinkslip Racer
couldn't i jusr re-tighten it if that were to happen? im pretty sure i saw a DIY on this site...but thats all? from the first guy's reponse he made it sound like my car would blow up or something...
Old Sep 30, 2006
RHCP0801's Avatar
why do you do it so much?
Old Sep 30, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
your car blowing up is the least of his problems. The problem is your ebrake may accidently fail causing the car to roll and potentially hit someone/something. Or your car may freakishly start revving because of a throttle problem and move anyways.
Thats why.. you should just put it in neutral...
Old Oct 1, 2006
againifall's Avatar
Go Team Venture!
put it in park you friggin idiot
once yer car screws up and takes off on yer stupid ***, rolls through an intersection and kills half a family its going to be a lil late to adjust the cable
i hope a bear eats yer stupid ***
Old Oct 1, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
sounds like hes a delivery guy...pizza maybe...
is it really that much effort to put it into park and drive i mean come on...
Old Oct 1, 2006
ya N is right next to D all you do is tap the shifter up one. you dont even need to squeeze the button.
Old Oct 3, 2006
karizzle's Avatar
Pinkslip Racer
why the would my car roll thru an intersection? i dont use it at lights. i do deliveries with my car, but its newspaper deliveries. and the times it takes me from going from D to P, after 200 times a night, actuall does add up and makes the difference between me finishing late and on time (since i usually finish RIGHT on time) and i did used to put my car in N, but then when i put it back in D i have to wait an extra second, or two, before i push the gas, otherwise the car will have a nasty kick. and as i said, those 2 seconds actually add up
Old Oct 3, 2006
AmbulanceMonkee's Avatar
I'm not going to be an @$$, but seriously, you have to take the time to release the ebrake, isn't that about the same amount of time it would take to put it back in drive from park?? You really shouldn't be leaving it in gear unattended. As a matter of fact, if there isn't a law against this, there should be. Your car will eventually hurt someone or destroy something. I suggest you purchase a new car with a manual transmission to break yourself of this habit.
Alternatively, if you leave your windows open, and dive into the car, rather than taking the 3 seconds required to open the door and get in, you will save yourself one second per stop. All those single seconds add up.
Ok, so I did end up being an @$$, sorry.
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
