window wont move
Old Sep 5, 2006
05civicFun's Avatar
05civicFun is an unknown quantity at this point
window wont move
put mirrors on, re-assembled door, window dead, tested switch, got signal from all but green (believe ground) so attempted to bypass ground, hooked wire into ground, set on bolt, sparks and fuse blew, im thinking the ground came disconnected while worming a wire through a grommet, yes or not
Old Sep 5, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
Check fuse #. Let me check.
http://www.megaupload.com/?d=PZLL0NH0
That is the window schematic electrical.
Last edited by nj_represent; Sep 5, 2006 at 08:47 PM. Reason: Automerged Doublepost
Old Sep 5, 2006
05civicFun's Avatar
replaced the blown one (22) and still not running, anyway, it blew after i dmm'd the harness, and all but the green had a current going
Old Sep 5, 2006
Check 6,23,22,24,25,13
24 and 25 if you have a sedan.
Old Sep 5, 2006
05civicFun's Avatar
its only the passanger side thats not moving, everything else is working fine, besides, it took me 10 mins to pull 22 and im to damned lazy to pull that many
Old Sep 5, 2006
What did you lose the honda fuse puller that thing kicks ***. What is DMM just wondering.
Old Sep 5, 2006
05civicFun's Avatar
digital multimeter, tells how many volts the connection has, and i got big hands, and the fuse block under the dash is cramped, but as i said, its only the green one thats not giving any reading anymore, the rest give off 12.2
Old Sep 5, 2006
CraigW's Avatar
The voltage for the passenger window motor should appear across RED & RED/BLU and then near the motor RED & BLU/WHT
The polarity of the voltage between these 2 wires (not ground) will change depending on up or down selected.
Old Sep 6, 2006
05civicFun's Avatar
somebody slap me, or slap honda for making the window lock kill the passangers window on the master control, it confuses us dumbasses
Old Sep 6, 2006
You have got to be ****ing kidding me.
dtdoyle
25
Aug 30, 2015 06:57 PM
Burgeogull
Aug 14, 2015 05:12 PM
jnissen
Aug 9, 2015 05:34 PM
breanna_17
Jul 21, 2015 04:01 PM
ballmich
Jul 9, 2015 11:59 AM
