Turbo problem!!! Help fast.
Old Aug 27, 2006
boostedEL's Avatar
boostedEL is an unknown quantity at this point
I just installed my tsi turbo kits and now for some reason my car cuts out at 4000rpm. when you restart the car its fine but after a couple of pulls, its does it again. pls help!!!
Old Aug 27, 2006
TheSmuggler's Avatar
Probably going into limp mode. This really should have been in the F/I section. Check your CEL's (most auto shops like autozone) will do it for free and tell us what codes your throwing.
Old Aug 27, 2006
boostedEL's Avatar
sorry if its in the wrong section. i was kinda in a hurry. my CEL is on but i dont have the codes yet. will get it tomorrow at the shop. but did anyone get this problem yet??? Thanks
Old Aug 27, 2006
Pretty much everyone that is boosted gets a CEL at least once.
Old Aug 27, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Car is probably seeing boost but of course you wont know for sure until you get the codes read. Buy a scanner from Autozone its only like $40
Old Aug 27, 2006
boostedEL's Avatar
Well ill know tomorrow. as soon as i get the codes ill post them. meanwhile
is it safe to drive my car? ill try not to hit boost.
Old Aug 28, 2006
boostedEL's Avatar
my only code is p1259.....
Old Aug 29, 2006
Originally Posted by TechTips
The VTEC oil pressure switch is a normally closed switch. The ECM sends a voltage to the switch and expects the voltage to go through the switch to ground. If the ECM reads a voltage on that circuit when the VTEC system should not be operating, it will turn on the "check engine" light and set a code. This code will be a P1259 on a vehicle with OBD-II.
Yikes
Old Aug 29, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
O snap!!!
good luck!
Old Aug 29, 2006
familycar's Avatar
sounds like a fuel cut issue. the vtec shouldnt be effected unless you rewired something. in this case you obviously wored it wrong. go back and check your wiring
Old Aug 29, 2006
boostedEL's Avatar
thanks for all the help. ill recheck my wires.
Old Aug 30, 2006
boostedEL's Avatar
now i got another problem. the icu does not want to keep my settings.
Old Aug 31, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
what holds settings in the ICU? Battery, constant power?
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
mikevtec
May 3, 2015 01:36 PM
CosmicPulse
Nov 9, 2001 05:06 AM
