Rewiring Spoiler LEDs
Old Aug 21, 2006
grifter1818's Avatar
grifter1818 is an unknown quantity at this point
Recently on my 2004 Civic EX, a few of the spoiler LEDs went out, what would be a solution to fix that? Is it possible to rewire them? or replace the leds that are out?
Old Aug 21, 2006
CraigW's Avatar
A poor solder connection(s) is a possibility at the LEDs leads solder point.
A quick test for poor solder would be tap lightly on the spoiler near the LED assembly when the brakes are on to see if the defective LEDs flicker on and off with vibration.
Old Aug 31, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
You dont have to rewire, I bet if you open up the third brake light you would find all the LEDs wired up in parallel and just a couple either have a cold solder connection or just burned out. Take a soldering pencil and pull out the defective ones find out what color they truly are. There are a MILLION types of LEDS on the internet you can find. Be carefull when testing the LEDs though they do not run on 12V, they run on a lower 1v-3v. You could also read amperage on the LED to match the right LED so its not a different color using a Ammeter aka voltmeter.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
frank_kleng
Sep 29, 2015 10:55 PM
EM2661
Sep 11, 2015 06:01 PM
Biggunschad
Sep 11, 2015 04:06 PM
