HELP!!! Right Front Brake Dragging
Old Aug 14, 2006
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
I just finished installing my Eibach Sportlines and got everything back together. Backed out of the shop and drove down the drive with the car struggling to move....Okay, this isn't right so I get it back into the shop and pull off the front wheels. The right brake is ICE cold while the left is burning up...I'm assuming that the ABS sensor is f'd up or something....anyone know what it is, which side....what part??????? I live 50 miles from the CLOSEST Honda dealer and 30 miles from any shop I would trust with the car...
***Left's dragging, rights fine***
Last edited by redrocket600; Aug 14, 2006 at 11:13 PM. Reason: Automerged Doublepost
Old Aug 15, 2006
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Were there any changes made to the rotors or brakes, new rotors new brakes anything like that or did u only work on the suspension?
Old Aug 15, 2006
I only changed the springs...and the only thing I messed with dealing with the brakes was, I removed the calipers to get to the lower strut bolt easier so....don't know.
Old Aug 15, 2006
solar's Avatar
solar is an unknown quantity at this point
If you removed the calipers than most likely you knocked the piston out of alignment and the piston is hung up. Remove the caliper in question, and push the piston back into the caliper until it's flush with the caliper housing, you may have to "rock" it back and forth until it frees up. Then replace the caliper and pump the pedal a few times, until the caliper adjusts and you should be fine.
Old Aug 15, 2006
I *hauled* it to the Honda dealer today.....they were VERY busy so they'll get to it tomarrow...I hope it's something as simple as the piston....
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
rhvic
May 22, 2015 03:06 PM
crowtoo
May 11, 2015 06:50 PM
bsmiley
Apr 27, 2015 01:27 PM
