Sticky clutch pedal?
Old Aug 10, 2006
dacivic's Avatar
dacivic is an unknown quantity at this point
Clutch fluid level is fine
No problem shifting
No problem engage the clutch
Happen in hot days in the afternoon
When the clutch pedal decompresses itself...it will stop/stick at a position (about 20% away from fully decompress) and then slowly moves back or soemtimes pops back to fully decompress. Anyone has this problem? Is it the fork problem? Please help!
Old Aug 11, 2006
Jeff's Avatar
Jeff is an unknown quantity at this point
clutch master cylinder. I had honda replace mine 5 times, yes 5 times for the same problem. Now that mine is out of warrentry i just use white litum grease and press in the clutch pedal and lube the shaft. Works for a couple of moths and then it will start all over again.
mrohitredd
40
Sep 9, 2017 12:03 PM
violentpanda
Sep 7, 2015 11:49 AM
JetsterDajet
Aug 15, 2015 08:07 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
