Drivers Side Door Lock Problems
When i use my keyless remote the drivers side door wont open or lock
does anyone know how to fix this, the passenger door opens sometimes and locks sometimes
thanks
thanks
For every sprinkle I find, I shall kill you.
If its only with the remote, then you probably need a new battery in it. If it still doesn't work when you use the power lock button in the car then that means your door lock actuator is going bad. Do a search for "door lock actuators" and you will find many many threads about this. There is also a DIY in the DIY section.
MamaBear2015
May 3, 2015 02:17 PM
