A/C Whistles
Old Jul 27, 2006
ES2Slow4Me's Avatar
ES2Slow4Me is an unknown quantity at this point
A/C Whistles
I searched with no luck. Every minute or 2, my car makes a high pitched "whoo" noise. It sounds as if it's coming from the driver's side engine bay (but that could be because i'm sitting there). It's only when the A/C is on. Doesn't matter how hard the fans are blowing, it makes the same noise whether i'm sitting there in the parking lot or driving while both accelerating and slowing down. I cant consistantly reproduce it. Any clue what it could be? '01 EX Sedan with about 90k miles.
Old Jul 31, 2006
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
It's your compressor engaging. Very typical flaw that you just have to live with. Mine does it too!
Old Aug 1, 2006
solar's Avatar
solar is an unknown quantity at this point
If the noise is the compressor making the noise, it's not a flaw, the compressor cycles to keep the evaporator from freezing up, it's designed that way.
The noise you're hearing can also be the condenser fan kicking on.
Old Aug 19, 2007
Stratablak314's Avatar
Stratablak314 is an unknown quantity at this point
Re: A/C Whistles
This thread's pretty old, but mine car makes this noise too. Sounds like someone peeps their head in your window and lets out a little whistle.. hahha. It sounds like "huh"? but whistled... haha that's the best I can explain.
Old Aug 20, 2007
DsevenEm2's Avatar
This is Myspace
Re: A/C Whistles
thats a funnny problem to have..no help here sorry but thats hilarious..sucks for u!
Old Aug 27, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: A/C Whistles
got the same problem....probably gonna mention it when I take it in to get serviced
Old Aug 28, 2007
VinhTEC's Avatar
VinhTEC is an unknown quantity at this point
Re: A/C Whistles
There is a TSB from Honda its not worth reading. Your car is normal like the other guy says when your car's a/c engages the freon moves through this really small valve in the a/c lines. Well imagin blowing through a really small hole it makes a whistle sound. Sometimes if you dont have enough freon it will do the same. Might want to check it but I wouldnt really worry about it until it stops working GOOD LUCK!!!
h4ldol
Apr 24, 2017 08:16 PM
jtcavey
Sep 30, 2015 02:18 PM
JMKendrick
Sep 16, 2015 06:17 PM
MichaelLW
Sep 14, 2015 07:15 AM
andyandyy
Aug 4, 2015 06:37 PM
