problem with starting
Old Jul 18, 2006
mateusz's Avatar
mateusz is an unknown quantity at this point
does anyone has problem with starting the car ?? sometimes i do i have to press lil bit of gas or turn the key like 5-6 times ??
what is the problem ???
Old Jul 18, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I heard from gearbox to put my car in accesory mode(3 clicks up) before starting it!
Because some times my car too wouldnt start!
Always worked for me!!!
Old Jul 18, 2006
ryangt's Avatar
ryangt is an unknown quantity at this point
yeah ive had mine not start a couple times, they kinda pick when they wanna crap out on you, just a lill gremlin i guess
Old Jul 18, 2006
mateusz's Avatar
yea exacly...what do i need to replace ?? GAS filter ??
Old Jul 18, 2006
ryangt's Avatar
dont think theres anything to replace here buddy,
Ive had it happen in cold weather, hot weather and everywhere in between.
I dont think theres a real fix. Just try putting the key in the acc position for a second before you start to give the fuel system time to pressurize.
Oh an pumping the gas pedal does nothing, these are fuel injected cars not carb'd so you can stop doing that cuz your only giving the throttle plate a work out
Old Jul 18, 2006
CraigW's Avatar
My 05 has done it a few times, As well as a low/rough idle IMO.
As mentioned turn key to on and wait until fuel pump stops making noise then crank it. And don't touch the gas pedal at all.
Old Jul 19, 2006
WhiteHalf's Avatar
WhiteHalf is an unknown quantity at this point
Well I had a similar problem, I have an 02 manual Si (Cdn version). What it ended up being was that my floor mat was sliding behind my clutch. I was freankin out, cause my car was brand new at the time and it was not turning over.
So just check, if it is a manual trans, that there isn't anything impeding the clutch pedal from going completely to the floor/back wall.
NOTE: the mat wasn't that thick at all, maybe half a cm at max, and it was causing it to not start.
CarStuff
Dec 6, 2020 12:52 PM
black2k1vtec
Dec 6, 2001 09:49 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
