Fuel filter clogged?
Old Jul 12, 2006
2k2civicsedan's Avatar
2k2civicsedan is an unknown quantity at this point
When I'm stopped at a red light my car starts ideling rough. Its not the A/C I can turn it off and it still does it. As soon as I press the gas to get the RPMs up it quits. The only engine mod is a short ram intake. I figured it might be a clogged fuel filter but the guys at the local service station said it was inside the tank. I need some help this.
Old Jul 12, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
how many miles on the car? how old are the plugs and what kind, oem?
Old Jul 12, 2006
82k miles and OEM plugs
Old Jul 12, 2006
ctx66's Avatar
in your shoes, id replace the plugs before i start messing with the fuel system. i noticed my idle got smoother when i changed my oem plugs @90k.
Old Jul 12, 2006
streetglower's Avatar
unbolt your cat converter and then recheck your car. its a possibility your cat is clogged.
Old Jul 13, 2006
Thanks. What kind of plugs are the best? I heard the irdium plugs aren't very good for the price. I want some high performance plugs. Thanks again.
Old Jul 13, 2006
ctx66's Avatar
My personal opinion is OEM. They have always been good to me for the first 90k i had them in, and the replacements i've had for 12k so far have been just as good.
if you have an EX, you want the Denso double platinums.
sparkplugs.com offers them at a great price. the dealer usually charges $16 each, they want $7 and change.
If you have an LX, you want the NGK double platinums. the dealer usually charges $17 each, they ask $11 each.
Regardless of which plug you choose, if either.. I think its money well spent. I dont plan on running these plugs as long as i did the first time, probably to 60k this time. so i dont mind spending $32 on plugs every 60k.
http://sparkplugs.com/results_app.as...1&AAIA=1415674
Old Jul 13, 2006
copper ngk works too. you might have a clogged iac valve. its the cause of most idle problems I see here.
brags
46
Jan 7, 2016 09:39 PM
Dani1993
Jul 24, 2015 09:02 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
