Heat Guage going to HOT when idle or in bumper to bumper traffic
Old May 15, 2006
Skydivincoastie's Avatar
Skydivincoastie is an unknown quantity at this point
I have an 02 Civic EX. I was doing a long drive home the other day when i got into bumper to bumper traffic on I-95, i looked down at the dash and saw my temp guage on HOT. I started moving again, it went back down to the middle of the guage where it normally sits. Whenever i start moving, it goes back down, when i sit, its up there all the way. Any suggestions on what it could be?
Danny
Old May 15, 2006
CraigW's Avatar
Is the cooling fan cycling on & off properly ?? Coolant level o.k. ??
Old May 15, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Man, I totally feel you. I've commented on every recent post like this.
Old May 15, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
could be the fan, or perhaps now, the headgasket.
if you notice your temp gauge on hot, then turn your car off
Old May 16, 2006
headgasket replaceable? is that a part that is replaceable, or do i need an entireley new engine?
danny
Old May 16, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
yes its replaceable. check yer coolant lvl too that might b one problem.
Old May 16, 2006
billiardini's Avatar
billiardini will become famous soon enoughbilliardini will become famous soon enough
im having the same problem dude.. from what ive been reading the past couple of days it could be a bunch of things.. either a thermostat, radiator cap, coolant level, possibly head gasket, fans.. it seems like this is a common accurance in our rides.. Im gonna be taking in my car for a coolant check to see what the problem is, seems like the best idea for now since it could be so many things its hard to know.. Do you have any coolant spilling from the overflow?? did you check to see if your oil is not a milky color??
Old May 16, 2006
took the car in, no problems with leaking, no problem with the cooling system, problem is a small exhaust leak. Mech said it could possibly be a blown head gasket way past anything. Mite have destroyed the engine..not sure yet...I dont know what to do..im a military guy makin like little $$.
Danny
Old May 16, 2006
gmcuajo's Avatar
gmcuajo can only hope to improve
Originally Posted by Skydivincoastie
took the car in, no problems with leaking, no problem with the cooling system, problem is a small exhaust leak. Mech said it could possibly be a blown head gasket way past anything. throughtMite have destroyed the engine..not sure yet...I dont know what to do..im a military guy makin like little $$.
Danny
Do you check all the other things? Check if the fans are turning on.
It comes down again when go fast (at high speed) or just for moving the car. If it is when you go at high speeds it could be the fans. When the car is stop and the temp goes up the fans should come on. When you are at high speeds the wind air colds the radiator.
mikemc422
Aug 9, 2018 05:41 PM
Mercilus
Jun 7, 2015 10:00 PM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
trevor
Dec 4, 2001 04:12 PM
