pre-problem diagnosis
Old Mar 10, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
man, I dunno what is gonna happen, but it's never a good sign when you're idle speed drops while you're stopped at a light in an automatic. sitting there, minding my own business in D, with the idle around 650-700 or so, when it drops suddenly to the 500 and lower mark and starts to sputter. I push it into neutral and rev it to 2k for a little and the light changes and I wait for it to drop and shift then. doesn't happen again at all. this is the first time it's ever done that. I code scanned the car and nothing came up, and I've been keeping an eye on her. something tells me its a matter of time until something gives now. I'm thinking either alternator (cuz my lights are dimming more than usual when I do stuff) , or my belt is slipping. any other ideas for me to check on?
Old Mar 10, 2006
just pull off the throttle body and clean the iac sensor. see all nice and clean after spraying a can of carb cleaner in there and getting all the carbon out.
Old Mar 10, 2006
shroomster's Avatar
I'll probably do that this coming friday when my shop lets me work on my car.
we got some strong-assed throttle body cleaner from I think midwest (yellow can) like a case of it is like 90 bux or something only 6 cans though....
Old Mar 12, 2006
shroomster's Avatar
Originally Posted by gearbox
well I gotsa update. don't quote me on the readings but I load tested the batt and then the alternator. the battery is fine. the car was started and we had the alternator hooked up, we put a load to it, and it moved maybe 1-3 amps from 40. sooooooooo i guess I'm going to be replacing the alternator. and in that pic Gearbox, what is that pic of? I can't tell because of the angle ...but I opened the butterfly valve and sprayed down in there, it was clean btw, for the most part, if the metal under the butterfly is a gun metal like color....
Old Mar 12, 2006
Its the IAC valve on the left of the throttle body. those two holes with the 3 on it is for the coolant hoses. that valve is usually covered with carbon and can get stuck, causing erratic idle.
Bruce2
Sep 27, 2015 08:45 PM
Bruce2
Sep 21, 2015 08:01 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
alinaray
18
Aug 24, 2015 01:04 PM
alaga
25
Aug 13, 2015 04:42 PM
