broken motor mount
Old Feb 11, 2006
02blkhonda's Avatar
02blkhonda is an unknown quantity at this point
broken motor mount
well my front motor mount is broken...idk how it happend , but a member said he would hook me up when he got his new swap on the 20th of this month...does anybody know if it will hurt my car to drive it while i wait for the new mount
Old Feb 11, 2006
R1Style's Avatar
well you're basically putting more stress on the other mounts. Drive it really carefully and as smooth as possible because you could potentiall break the other mounts.
Old Feb 11, 2006
02blkhonda's Avatar
cool....just along as i can still drive it until i get the mount i will be striaght
Old Feb 12, 2006
02blkhonda's Avatar
does anybody know if the auto motors mounts are the same as the 5sp....i have a junk/parts civic at my granny's house and i do not want to drive all the way up there for nothing....anybody know?
Old Feb 13, 2006
gmcuajo's Avatar
gmcuajo can only hope to improve
I think the front mount is the same, the rear not. however, you can check it at slhonda.com doing a comparrison of the part numbers.
And with the new mount install the inserts, or you will have a worn mount soon...
Old Feb 17, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Talking
I'v gone through like two sets of motor mounts Gota love VTEC on the freeway
Old Feb 17, 2006
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
I just had my trans rebuilt a few weeks ago (105k miles) and they noticed my front engine mount was busted. God knows how long thats been broke.
Old Feb 18, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
oh yeah I just took my car in this morning. I have 3 busted mounts, all being replaced under warranty.
Old Feb 18, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
i dont get it, how can your mounts get fkd up if they are ment to hold down your engine? do they move or omsething?.......
Old Feb 18, 2006
DDragon7's Avatar
Your engine moves, and the mounts are subjected to the engine movement, they are like dampers that stop the engine from moving too much and to reduce the vibration that you feel.... something like that.
Old Feb 18, 2006
spoonJDMlX's Avatar
lol o, should i get mine checked out? never been changed..obviously...cars at 52000 already
Old Feb 22, 2006
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
You have me thinking about this now. Think I should have it checked out, I keep hearing a rattle coming from the left driver side when taking off and when hitting small bumps.
Old Feb 22, 2006
02BLKCIVIC's Avatar
Talking
It happens whene you have a "lead foot!" Or are way to heavy on the on the gas pedal.
Old Feb 22, 2006
spoonJDMlX's Avatar
ahha, i seeeee...yeah i better get mine checked lol
Old Feb 22, 2006
02BLKCIVIC's Avatar
^^^ Couldn't harm the car! Thats for shure. Every time I replaced mine the car drove SOOOOOO smooth!
Old Feb 22, 2006
spoonJDMlX's Avatar
k throwa link at me, which one should i buy?
Old Feb 22, 2006
02BLKCIVIC's Avatar
Talking
OEM HONDA MOUNTS! Thats all I buy. Not aftermarket mounts. sooo where ever your local OEM dealer is will do.
Old Feb 22, 2006
DDragon7's Avatar
Will it cost alot to replace the mounts with labour?
Old Feb 22, 2006
evangelize's Avatar
evangelize is an unknown quantity at this point
well, it cost about 50 dollars for each mount.. and the labor cost is about 180 if you want to replace all 4 mounts... so, about 45forlabor+50 dollars for the mount... i actually i got 2 motor mounts and transmission mount replaced for 150 with labor... but thats because it was my friend's dad shop.. but good luck to you...
Old Feb 23, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
How do you change the mounts (is it something you can do without dropping the engine) and how do you check if you have bad ones. When i rev the engine, it rocks but I don't have any vibrations or anything.
Old Feb 23, 2006
it happens from junk mounts. if they are available, go aftermarket. you'll be able to tell by looking usually they will be cracked or damaged. if you dont feel bad vibrations they are prolly fine for now.
Old Feb 23, 2006
02BLKCIVIC's Avatar
I'v replaced my clutch twice, sooo each time they droped the engine out I had them replace the all the mounts at that time. (to save on labor later on) But I SAW the mount is was a shreded peace of plastic and metal.
Old Feb 23, 2006
Okay so let me get this straight, if I do need to replace them. Are OEM mounts the best to go with on the replacement.
Old Feb 23, 2006
02BLKCIVIC's Avatar
Lightbulb
See, I dont THINK there is mutch aftermarket suport when it comes to engine mounts. But I was TOLD just to get the OEM one's. The reason I have replaced mine twice was "operator error." I.E Drag Raceing on the track and all over the street. Again this is just my oppinion
Old Feb 23, 2006
uh i think a car should be able to drive to its potential without breaking. the car has less than 100hp
Old Feb 28, 2006
LXracer's Avatar
LXracer is an unknown quantity at this point
just dont go chirpin 5 gear TEEHEE
Old Feb 28, 2006
familycar's Avatar
you will notice excessive movement from the motor if the mount is broken when you rev it. you will also see some movement in the shifter when releasing the clutch when starting out. its not a huge deal unless others are broken too. just take it easy and as far as using factory mounts- think about how fast they went already aftermarket should be stronger and be able to take more abuse with out breaking but they will also cause more vibration becasue most of the time the inserts they use are stiffer
Old Mar 1, 2006
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
stupid Hondas! j/k
Old Mar 5, 2006
Black03civic's Avatar
were would you guys recomend getting aftermarket motormounts? I just found out that my front one was crack in half on friday.
Old Mar 14, 2006
gmcuajo's Avatar
the front mount is made weak for safety. if you have an accident this mount brakes so the engine fall to the floor and don't hit the firewall. but apparently it is too weak and break easly. I recommend the use of "energy suspension inserts"...
Most pf the times you don't have to replace all the four. the front mount and the one that is on the timing belt side are the most that fails.
the front is around $60, the side (timing belt) is around $100
you could inspect them, if the rear aren't broke the other three you can replace them by yourself, even if don't know anything about cars, "just have to know how to bolt and unbolt a bolt", the rear is the same but with a little space
just unbolt it and install the new mount in the same form the other was, torque it with a 3/8" ratchet and that's all, for the timing side mount you should use a long (deep-well) socket
OBVOUSLY REPLACE ONE AT A TIME, AND DON'T START THE ENGINE OR DRIVE THE CAR
i haven't see any aftermarket mounts, use the energy suspension inserts, you will feel vibrations on the car but the mount will not fail anymore, if you don't want the vibrations install the inserts just to the front mount, the rear one doesn't break (it don't tends to)...
if any mount is broken you should replace it inmediately, it is a deal, if you don't replace them the other mounts will break
the mounts control the movement of the engine, excesive movement of the engine can cause other engine problems especially on a manual trans. the clutch, pressure plate and flywheel can be damaged...
