broken motor mount
Originally Posted by gmcuajo
the front mount is made weak for safety. if you have an accident this mount brakes so the engine fall to the floor and don't hit the firewall. but apparently it is too weak and break easly. I recommend the use of "energy suspension inserts"...
Most pf the times you don't have to replace all the four. the front mount and the one that is on the timing belt side are the most that fails.
the front is around $60, the side (timing belt) is around $100
you could inspect them, if the rear aren't broke the other three you can replace them by yourself, even if don't know anything about cars, "just have to know how to bolt and unbolt a bolt", the rear is the same but with a little space
just unbolt it and install the new mount in the same form the other was, torque it with a 3/8" ratchet and that's all, for the timing side mount you should use a long (deep-well) socket
OBVOUSLY REPLACE ONE AT A TIME, AND DON'T START THE ENGINE OR DRIVE THE CAR
i haven't see any aftermarket mounts, use the energy suspension inserts, you will feel vibrations on the car but the mount will not fail anymore, if you don't want the vibrations install the inserts just to the front mount, the rear one doesn't break (it don't tends to)...
if any mount is broken you should replace it inmediately, it is a deal, if you don't replace them the other mounts will break
the mounts control the movement of the engine, excesive movement of the engine can cause other engine problems especially on a manual trans. the clutch, pressure plate and flywheel can be damaged...
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
