engine is vibrating and acting really funny
Old Feb 10, 2006
02blkhonda's Avatar
02blkhonda is an unknown quantity at this point
so I was going to see my granny and she lives on a 2 lane curvey country road, sounds like fun huh? well it was all fun until i pull into the driveway and get ready to shut the car off and noticed that it is vibrating very hard. I was running the dogshit out of it, so when i was leaving the it kinda acted like the battery was weak and had to try a little harder to start. so im drivring home and decide to see if it has lost any power and no it still feels like full power, but when it hits bout 5500 rpms the lights dim a little and then when i shift the get bright again . ok so now i am baffled and i am sitting at the house and just revving it slowly to see what it does. so i try to hold it at 2000rpms but it would go up a couple hundred and then fall back to 2grand. over and over again. and then i notice that my front/bottom engine mount looks like it is slanted and doesnt look like the other ones???? does anybody know what the hell is wrong with my car, it is 02 ex 5 sp, no engine light, the motor sounds like it is making some noise but i cant tell if it is just from the vibrations or what
Old Feb 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
maybe you broke a motor mount ... it happens ...
Old Feb 10, 2006
02blkhonda's Avatar
but would that make the car rev funny like that...or do i just have a shitload of things wrong with my car? and how hard is a motor mount to replace????????
Old Feb 10, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
no idea. could be anything ... low oil levels, dirty iacv, busted tps, incorrectly torqued spark plugs, etc ...
Old Feb 10, 2006
02blkhonda's Avatar
what is iavc????how hard is it to replace the bottom/front motor mount
Old Feb 10, 2006
post a vid
Old Feb 10, 2006
PunkingCivic's Avatar
I need TP for my bunghole
not hard, just support the engine from below with a jack, put a 2x4 between the oilpan and the jack. Don't jack the up just support it. Then take off and replace one mount at a time.
Old Feb 10, 2006
02blkhonda's Avatar
will i have to change all of them?????and what would cause the misfiring, the plugs only have bout 8k miles on them. the car has bout 100k miles but the missing only started after it started vibrating like it is......maybe i have broke something in the bottomend idk???no smoke and it runs fine
Old Feb 10, 2006
do you have to change them all? You tell us.
Only if they are broke/cracked.
Hell, you might not have to change those at all.
How clean is the filter? it can make the engine act funny itf it is really really dirty.
Best thing is have a place scan the ODB II and see if it is throwing an error of any kind.
Of but a ODB II scanner you self an look up the codes here: http://www.troublecodes.net/honda/hondaobd2.shtml
Old Feb 10, 2006
02blkhonda's Avatar
ok but will it throw a code if the egine light is not on???which filter??you talking bout the oil filter or the air filter????
Old Feb 10, 2006
02blkhonda's Avatar
also the right wheel is wheelhopping really bad????maybe i need new axel
Old Feb 10, 2006
Have a the tire rebalanced the wheel probibly through a weight. Or you have a bad tire or dented rim. Either way they will tell you.
Old Feb 10, 2006
Air filter
also error codes can still be given without the engine light coming on.
Old Feb 10, 2006
go buy on of these. I think walmart sales them:
Old Feb 10, 2006
02blkhonda's Avatar
ok but does that tell you how to diagnose problems????could the cv joint or the axel cause it has been clicking when i turn to the right...but that wasnt a big problem cause i have a friend with a totaled auto civic that i get parts off of. also will an auto civic motor mounts fit a 5 sp?
Old Feb 10, 2006
cv joints have nothing to do with your problem.
Old Feb 10, 2006
Civicman1988's Avatar
You might need new motor mounts my brother had that happen on his focus.
Old Feb 11, 2006
02blkhonda's Avatar
when a motor mount breaks...that can make your car wheel hop really bad??i am going right now to scan it using one of those scan tools my friend has..will post results
Old Feb 11, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
Actually a bad axle will make your car ride funny. Also why would a bad engine mount throw a cel and dim his lights. What about your alt going bad? have you thought about that also. If you wanna see if the vibration is cause by a bad axle or wheel bearing. Dont be scarred put the front on jackstands start your car put it in first and let your wheels spin. If either your axle or wheel bearing is bad you will know due to the vigorous shaking you will see.
Old Feb 11, 2006
02blkhonda's Avatar
cool I will try that when this damn rain clears up....and what you were saying bout the bad mount throwing a cell???I assume you were talking bout a battery cell, and if so would that be the cause of the lights going dim after about 55oo rpms?I think the battery is pretty shitty, it is the one that came from the factory and it has been drained about 5 times(i have left my lights on several times)(and no i didnt hear the damn noise when you do it) so maybe the battery is just really weak
Old Feb 11, 2006
Slow Gold's Avatar
Do you have a system?
Old Feb 11, 2006
02blkhonda's Avatar
yeah i have one polk momo 12 and a 400w amp....that is it tho
SuziQ
138
Dec 12, 2025 10:04 AM
mrohitredd
18
May 14, 2015 07:35 PM
jakeconnor
May 5, 2015 07:30 AM
tylerginevan
Apr 27, 2015 12:29 PM
streetglower123
Apr 12, 2015 10:56 AM
