03 civic ex transmission.(already searched)
Old Jan 17, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
my syincroids or w/e are goin bad when i go into 3rd gear, anyone know where i cab get a brand new transmisson or anything?? its a 2003 civic ex 5speed
Old Jan 17, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I have the same problem. Im tiring of fighting with the dealerships. Im bout to buy a used one if the prices are right.
Old Jan 18, 2006
junkyard
Old Jan 18, 2006
R1Style's Avatar
Is your car no longer under warranty? Take it into Honda.
Old Jan 18, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
rebuilding kit....thats what ima do!!
Old Jan 19, 2006
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Buying a used 7th gen tranny is just a band aid. Rebuilding with BETTER parts is ideal. BTW, I just bought an 85 Nissan 4X4 with a good 145000 miles on it. Guess what? Shifts perfectly. They sure were built better back then. Now I just have to get the 200 pounds of mud back off the truck....
Old Jan 19, 2006
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
There is a TSB on this somewhere... (someone please chime in)
There is somthing about 2nd, 3rd, and 5th. I have the same problem. try contacting Honda First. Get a copy of the TSB. Take it to a tranny shop, with the TSB, and get a quote if Honda won't do it.
Old Jan 19, 2006
02blackcivic's Avatar
02blackcivic is an unknown quantity at this point
whats a tsb?
and the same thing is happening to me and i took it around to tranny shops and they said im better off buying a 96-99 d-series tranny and it should mate up to the tranny i have right now because it would be at least $1000-$1200 to rebuild my tranny
btw, i have an 02 ex coupe
Old Jan 19, 2006
dru106's Avatar
ThE CoRRupToR
A 96-00 tranny will not fit in our cars! The mounts for the tranny are totally different. I just got my tranny rebuilt for $2300 which is really bad. Everything was almost replaced. Goodluck at the junkyards cuz ive tried and outta the 5 shops i went only 1 had it which it was off an 01 with 45kmiles going for $800. These trannys are shitty unless its rebuilt, its not gonna last long if you get a used one. If you plan on keeping this car for a long time i say rebuilt it. Otherwise i would just buy a used tranny and sell pos this car!!!
Old Jan 19, 2006
ok, well i do live in hickville, USA so the tranny shop guys are rednecks and just make stuff up, i sent a letter to honda because along with my transmission, i have 7 other things that are wrong with my car, im thinking it may b a lemon, i dont knnow, so il see what honda has to say, if they say they wont help by grinding tranny wiht 42K on the odometer, il buy a used tranny, swap it in, and sell the car.
Old Jan 20, 2006
02SILVEREX's Avatar
T-tecnical
S-service
B-bullitin
I belive the one to cure your problem is TSB#03-009(revised)
You can find it http://www.geocities.com/pfeifferper...ingrevised.pdf there.
And if you want the rest for your car/applicable model, then you can find them HERE
I hope this helps. I know it's in my future too. I have a proplem with grinding, and slipping out of gear.
Old Jan 24, 2006
spoonJDMlX's Avatar
dude dont geta used tranny. Get a rebuilding kit. Thats the best thing to do with 7thgens. All the trannies are messed up. Get this rebuilding kit
http://www.tciauto.com/sport_compact.htm
on the bottom, part #559100
Old Jan 24, 2006
02SILVEREX's Avatar
That kit would be fine, if he needed an overhaul... But he needs some gears and sync's too.
I like the kit though. Fot finding that one.
Old Jan 24, 2006
i may not be right, but i think they are for automatic trannies only
Old Jan 24, 2006
SlowStockCivic's Avatar
SlowStockCivic is an unknown quantity at this point
Maybe your truck's tranny was replaced at some point.
Old Jan 25, 2006
tinman's Avatar
Nope. The engine was
My second, 2wd 85 nissan has 158000 on everything original. I needed a new input shaft bearing, so just had the tranny serviced. It shifted great before, but was noisy. Now it's quiet and shifts like crap. They should have left the original synchros alone.
The 4X4 is fine, though. The drive train apparently outlasted the motor.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Pr0n1s
Apr 30, 2015 03:08 PM
bsmiley
Apr 27, 2015 01:27 PM
alexkharden
Apr 23, 2015 07:13 PM
