help ASAP civic wont start
Old Jan 10, 2006
ryancivic's Avatar
ryancivic has a little shameless behaviour in the past
past two days i noticed the civic wasnt starting up as nicely as it used to and now today it starts to turn over but wont battery is fine bc lights still come on but it will not turn completety over NEED HELP asap lol i have school tomorrow please help
Old Jan 10, 2006
streetglower's Avatar
sounds like the fuel pump went out. go out to the car and turn the key to the II position and see if you can hear the fuel pump run for 2 seconds. if not you may have a failed fuel pump or bad fuse or relay. First things first, check the fuses, if those are good, check for fuel pressure and spark. you need both to turn over the engine. along with compression.
Old Jan 10, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
...i wouldn't rule out battery just yet...
has it been cold the past couple days?
how old is the battery?
i found that the lights will still be working...even the horn sounds strong...but if its cold...an older battery won't have the juice to start it.
my gf's bro has a wrx that wouldn't start....lights were all good horn was loud...but the battery was the original from 2000(i think)...he replaced it and it starts better.
try to jump it and if it starts its prob the battery...if not well....its prob something more expensive...
....also this is what i learned from workin on quite a few bikes...batteries should be at around 12.5-12.8 volts to be at full charge. a battery at 12.2 v may mean a bad charging system or the battery just won't hold a charge anymore...i think this applies to all 12v batteries....
Old Jan 11, 2006
If it cranks, but wont start, then the battery is fine. If it doesnt crank over, then I would have the battery tested.
Old Jan 11, 2006
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
is ur car making any funny sounds when u turn the key>/
My starter went out 3 times since i had it, this sounds like the same prob i was haviing.
Get ur battery tested first if it isnt the battery its gotta be the starter
thats my two cents.
Cheaper thing first. Starter is only like 150 and like 30 minutes to put in
mine didnt make a sound when i turned the key.
good luck its probally something simple.
Old Jan 12, 2006
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
i would say the battery, you said it turns over but not COMPLETELY... that sounds like an electrical problem to me
Old Jan 12, 2006
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
I agree with streetglower, he knows his stuff too. I like how you say ASAP, its not like your going anywhere. heh
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
SpoonSportsD17
Oct 23, 2001 01:38 AM
