Shifter Lights Don't Illuminate!
Old Dec 24, 2005
dudelikeduck's Avatar
dudelikeduck is an unknown quantity at this point
Hello everyone, I drive a 2001 Honda Civic EX, at the moment. The shifter lights for my 2001 Civic EX Auto do not illuminate anymore. How can I fix this? A fuse? I have the car's manual, but the fuse diagram doesn't indicate which fuse is reserved for the shifter lights.
Thanks.
Old Dec 24, 2005
CraigW's Avatar
The ones on the cluster, or on the floor shifter ?? Are the lights for the heater controls working ?
Old Dec 24, 2005
The lights located right by the shift lever. (P, R, N, D... etc.) They're not illuminating. EVERYTHING else is ok though.
Old Dec 25, 2005
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
I think it could be a loose wire harness in the dash (where the stereo is). Do you have an aftermarket stereo? I would pull the center dash and make sure all harness are fastend correctly.
Old Dec 25, 2005
CraigW's Avatar
Maybe someone here who has done this bulb change could chime in. #74 I would guess unless Honda uses a special bulb for it.
Old Dec 25, 2005
its prolly a bulb blown. I took mine out cause it was distracting seeing lights shine up at me. you need to remove the console piece and then there is a small socket that you can twist out. I think the bulb pops out and its kinda small you gotta take it out and check but I think its #74
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
StLVtec
Nov 14, 2001 09:22 PM
TropiKalCiviC
Nov 8, 2001 10:13 PM
