Clutch?
Old Nov 4, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
Clutch?
I'm driving home yesterday and and I'm in 5th gear. I go to pass a truck and drop into 4th. Thats when the problem started. It was a normal shift except when I went to give it some gas, the car didn't go forward like it should. So now I'm driving in 4th and the rpms are level where they are supposed to be, only everytime I try to accelerate, the car doesn't pull forward and the rpm's just rise. It was almost like my clutch was pressed in everytime I tried to acclerate. I coasted for as long as I could and pulled over. It had that clutch burning smell. The car will go into any gear, it just won't take off.
It's a 2001 EX 5 speed, 85,000 miles.
Old Nov 4, 2005
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
i dont know but i have a 2001 ex coupe 5 spd ... with 91k miles ... dont go cursing me with the clutch problem im broke as a joke right now ...
Old Nov 4, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Yea, anyone know a good way to check the condition of the clutch?
Old Nov 4, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I don't know of a way to check the clutch w/o pulling it out, but it seriously sounds like it's new clutch time for you. 85K is a little early but def. not unusually so.
Old Nov 4, 2005
Jrfish007's Avatar
yeah, 85k is a little early, but normal if the car is drive aggressively. You should probably check the clutch fluid make sure you did not use it up or something silly like that But it sounds like a fried clutch to me.
Old Nov 4, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
yup deffinetly sounds like the clutch
Old Nov 4, 2005
DDragon7's Avatar
A little test that I was taught, tho I have never used it, but have seen it: car on, handbrakes engaged, clutch in, put to first gear, n drop the clutch, the car should stall instantly if the clutch is good, or jerk forword a little bit first then stall if its slipping, or in your case, the car might not stall at all n your clutch is totally dead.
Old Nov 9, 2005
LayinLo's Avatar
Dragon, Yeah, I did the little test and the car engine keeps running. No stall. I guess I'll be taking it somewhere tomorrow cuz gas is killing me in the Silverado!!! I'll let you all know how it goes.
Old Jan 4, 2006
Eclectic's Avatar
Eclectic is an unknown quantity at this point
just curious, how many miles should the stock clutch last?
Old Jan 6, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
im not sure but i have 111,000 miles, and i drive pretty hard. No problems yet.
Old Jan 7, 2006
Eclectic's Avatar
hmm, thanks for the info
Old Jan 7, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
ahhhh tihs is why automatic is the best....nvm i said that.....my tranny is slipping.
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
