RPM goes up and down
Old Aug 11, 2005
return_2020's Avatar
return_2020 is an unknown quantity at this point
Here is the problem i m having. civic MT, 2003, 42000 miles. I had my oil change (myself) about 400 miles ago. Now I starrted expericing this problem. 1: when i start my car it starts at around 1500 RPM, it was starting around 1250 RPM, ( i know you would say wearther effects, but trust me, its same) this is when i noticed something strange. Now after driving around, when its in netural, it stays around 1000 rpm and drops to around 750 rpm after 20-30 seconds(this wasnt the case, it was dropping to 750 rpm). and now when the engine fan kicks in, rpm goes a little bit high, around 1250 rpm, also when i turn the steering around. rpm goes high. Any idea whats causing this ? please advise.
Thanks
Old Aug 11, 2005
PunkingCivic's Avatar
I need TP for my bunghole
it sounds about normal to me.
for the steering, it is all run on belts so the rev will go up a bit.
Old Aug 11, 2005
but what about when its in netural and stays to 1000 RPM ? this was never happening. it was always coming down to normal which is 750 RPM.
Old Aug 11, 2005
when was the last time the airfilter was changed or cleaned if you have a K and N.
Old Aug 11, 2005
i would say around 12000 miles ago. shouuld i check ?
Old Aug 11, 2005
wouldn't hurt, the engine could be straining to pull in more air
worst case reset the ecu; disconnect the batter for a few minutes. This will make the computer adjust itself.
Old Aug 11, 2005
streetglower's Avatar
Thanks
Now is the car running any different then before?
Most everything you described is normal. When you first start the car, the engine is cold so RPM's will start off a bit high. Once it warms up, the RPM's come down. Now anytime the engine has a load on it, the rpm's will increase a bit, but usually the IAC (Idle air control valve) will kick in and even out the idle (RPM's). Same with the steering, when you turn the wheel left or right, you are building pressure in the system which is basically adding a load on the engine. Now there is a Power steering pressure switch on the steering rack (Rack and Pinion) that sends a signal to the computer to bump up the idle when it senses a load change.
Old Aug 11, 2005
I agree with both of your response. But one thing is it doesnt seem normal to me. but let me try resetting the ECU. and see what happens. could it be little more oil when i changed the oil ? i know i added 3.7qt oil with the filter. but let me try resetting the ECU. thanks and let me do this first.
Old Aug 11, 2005
i did reset the ECU and took the K&N filter to check and filter was good. after putting negative cable back in and running car for 10 min. everything looks fine. lets see what happens next. what could have caused it ? any idea ?
Old Aug 12, 2005
Jrfish007's Avatar
Sounds like the idle curve got screwed up some how. It's happened to a few people on here before. Go to the link, gearbox talks about how to do an idle relearn if the problem surfaces agian, this should take care of it.
http://www.7thgencivic.com/forums/sh...d.php?t=221592
Old Aug 12, 2005
yeah i did reset the ECU by taking off the negative cable and letting car run for 10 min, but havent drove the car yet. lets see if this has resolved it. if not then i will do it agian. thanks a lot
Old Aug 22, 2005
bluestreak's Avatar
bluestreak is an unknown quantity at this point
^ I've got the same problem, however the rpm's go up to 1500 after warmed up, I've already done this re-learn and still the same problem?????
Old Aug 22, 2005
Jrfish007's Avatar
When it warmed up? what about when the car is cold, how long does it take to get to this point?
Old Aug 22, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I've had this same problem for the longest time ... resetting it didn't help me ... it just idles at 1k rpms until I come to a complete stop ... but it'll drop to 750 after 2-3 seconds ...
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
NROD315
Sep 23, 2015 03:46 PM
Juanb24
Sep 15, 2015 12:39 AM
