Problem with Door panel - 05 coupe
Old Aug 8, 2005
phobix's Avatar
phobix is an unknown quantity at this point
Today while washing my wife's car I noticed that the door trim/panel had become separated from the retention clips and there was a piece of plastic hanging down. I promptly banged it back into place but couldn't help to feel a little troubled by this. The car only has 4000km and already I have problems with the door panels falling apart. This is not the Honda I knew, has anyone else experienced such poor assembly with a 7th gen civic? I thought that all the assembly issues and bugs would have been ironed out having a late build civic at the end of its lifecycle, I guess I was wrong and even more troubling is that cost cutting is more evident than ever with this iteration civic.
Old Aug 8, 2005
20civic01's Avatar
20civic01 is an unknown quantity at this point
both my door panels are broken. the driver's side might be cause i closed it on my belt buckle once or twice. but that's never happened in any other car i've had. i dunno. and the passenger side maybe cause i was broken into twice. i dunno though. my car is just falling apart.
Old Aug 8, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
so it just came loose? i havent had any problems with my 03. Have you taken the panel off at all? You may want to take it off and make sure all the retainer clips are properly attached in their slots. If not, then just banging it back may crack the slot they sit in. When you say plastic was hanging out, do you mean like a clear plastic sheet or like a peice of the same plastic on the door?
Old Aug 10, 2005
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
i have the same problem with my driver side door, it pops out at the bottom
Old Aug 10, 2005
Do you have dynamat or anything behind it? Check the clips, the white clips crush pretty easily.
Old Aug 10, 2005
Jrfish007's Avatar
I had a pillar piece fall off, dealer replaced it for free
But yeah, check the clips if it falls off again, they just cheap little clip that are very easy to break.
Old Aug 10, 2005
i just bought some more of the clips cause a few of mine were broken. Honda wanted 3.89 each! i bought a package of 10 from here http://northlandfasteners.biz/Store/...6f0e36b3a76452 for about 6.50. just a tip. shipping was fast, service was good. they have about any clips you would need. this link is to the page with the door clips on it.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
MamaBear2015
May 18, 2015 07:37 PM
timpan
May 18, 2015 07:06 AM
MamaBear2015
May 3, 2015 02:17 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
