Brake help
Old Jul 6, 2005
y.0. KiLLa's Avatar
Powered by Honda
Brake help
hey guys i seem or i believe i have a brake problem...before when i first got my car as soon as i taped the brake the car came to a stop, now i noticed that the brakes go lower n lower, my mom even noticed it too. i changed my brake pads recently n my rotors look fine..do i need new brake pads again? hmmm
o0 yea soemtimes i guess mostly in the rain if i step on em hard they pulsate vibrate..can sum1 help a nooby out!
Old Jul 6, 2005
Zzyzx's Avatar
Autocross Junky
When is the last time you had your brake fluid flushed? blead? if you cant remember, have it done.
For pulsing in the rain... You have an EX right? if so, thats the ABS kicking in, so dont worry about it.
Old Jul 6, 2005
y.0. KiLLa's Avatar
Powered by Honda
ty..ill do that..so if i do that i should stop better n my brakes wont sink liek they do? thanks man for ur help..
Old Jul 6, 2005
Zzyzx's Avatar
Autocross Junky
Air in the brake lines is the #1 cause of a low squishy brake pedal... and its also the most overlooked mantiance part on the car.
Old Jul 6, 2005
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
YOU should replace fluid every 2-3 years. And a better fluid would not hurt, I personally use ATE blue.
Old Jul 7, 2005
tacheon's Avatar
tacheon is on a distinguished road
If your brake pedal sinks when you apply constant force to the brake pedal, and you have no leaks, your master cylinder needs to be replaced. Guaranteed.
Old Jul 7, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
I had the same problem with my old Accord. I would try to lock up the brakes on purpose and they wouldn't lock, just come to a slow stop. I would bleed the brakes and they would be fine for a little while, but the problem would come back after awhile. So I replaced the master cylinder and the problem was gone. My Accord had 110,000 miles on it though. How many on your car. I'm guessing they just need bleeding and or fluid replacement. Is the fluid milky looking and not clear? How far do you pull up your e-brake handle before it stops? Did you replace the rear brakes too? Does steering wheel vibrate also?
Old Jul 7, 2005
y.0. KiLLa's Avatar
Powered by Honda
u know my steerign wheel does vibrate n has always since i first got the car...my car has 35, 000 miles...how much would this master cylinder cost? well if i stomp on the brakes they stop but it sinks...i should just get a brake kit..how much is like a good brake kit? i think these r fugged up
Old Jul 7, 2005
dariusld's Avatar
When I say vibrating steering wheel, I mean while braking.
Old Jul 7, 2005
y.0. KiLLa's Avatar
Powered by Honda
o0 then no..sry lol..
Old Jul 8, 2005
tacheon's Avatar
Okay. First of all, a brake kit and bleeding your brakes isn't going to fix a faulty master cylinder. From what you described, it is obvious that the master cylinder has failed. This is a serious problem since you have a severe loss of braking power. The vibration is another issue and possibly related to the rotors and pads, but first and foremost, get your master cylinder replaced asap.
Old Jul 8, 2005
dariusld's Avatar
If the master cylinder has FAILED, he wouldn't be stopping at all. He wouldn't be driving car, for very long, that wouldn't stop. From your computer chair your going to say "ITS YOUR MASTER CYLINDER".
Old Jul 8, 2005
y.0. KiLLa's Avatar
Powered by Honda
i have warranty..will honda cover this master cylinder? i think imma have my mechanic check it out..just to clear things up i stop n stuff. i just noticed that the pedals go down more then b4...so i think maybe its a problem but i dunno..
Old Jul 8, 2005
tacheon's Avatar
There is a primary and secondary cylinder to a master cylinder. It is designed so you won't lose complete braking power when you develop a leak in the system. usually both function when you are braking. If one fails, you can stomp and brake or pump the brakes to stop. The master cylinder is like a double plunger. You can stomp and force fluid with the plunger, but if the seal around the plunger is bad, holding the pedal will cause the fluid to rush past the seal. This is what causes the pedal to sink when you brake and hold. This is the only thing which would cause the pedal to sink when you hold it, yet provide braking power when you stomp on it. Knowledge of how the actual braking system works would bring you to this conclusion.
Old Jul 8, 2005
tacheon's Avatar
A low pedal is not the same as a pedal which sinks as you brake. Pedal travel will naturally be longer as the brake pads and shoes wear.
Old Jul 8, 2005
y.0. KiLLa's Avatar
Powered by Honda
ok ty..my mechanic will check it out..ty for ur help sir.
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
