clutchless shifting??
Old Jan 24, 2002
Ichiban's Avatar
Ichiban is an unknown quantity at this point
I don't know if the car is suppose to do this but my car can shift out of gear easily without the clutch...my friend said that this is normal but it didn't do that before. Is this really normal??
Old Jan 24, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
while the car is moving or parked?[IMG]i/expressions/face-icon-small-confused.gif[/IMG] i can shift without the clutch when it's parked
Old Jan 24, 2002
DaPipeLayer's Avatar
AAAAHHHHH!!!!!
DaPipeLayer is an unknown quantity at this point
I don't think its a good idea to shift without clutching while driving. It will mess up your transmission, well thats what I heard anyways, correct me if I'm wrong please.
Old Jan 24, 2002
01civicboi's Avatar
when i say parked, i mean when the engine is NOT on. the clutch is your friend. use it since you have one on your car, unless u wanna hear some major gear grinding. that sound gives me chills[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Jan 24, 2002
89HondaLxi's Avatar
89HondaLxi is an unknown quantity at this point
you can take it out of gear while moving as long as you go to neutral.....as for shifting without the clutch from gear to gear....you can but its hard, take a look at NASCAR they do it all the time you just have to match the acceleration with the trani and keep the right RPMS
Old Jan 24, 2002
Ichiban's Avatar
So its normal for a car to be able to do this??...I can do it when im driving. I can't go into gear but I can get to neutral without the clutch...I don't do it but i know it can be done I just wanted to know if there was something wrong...Thanks
Old Jan 24, 2002
89HondaLxi's Avatar
nope its fine.....
Old Jan 24, 2002
DJNuTzSaK's Avatar
DJNuTzSaK is an unknown quantity at this point
its normal but if you do it incorrectly you can cause some major damages...
Old Jan 25, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
when u can get the transmission and the egine in perfect timing u can shift without using ur clutch
it is very normal I some times do that but becarful cause with out the perfect timing u WILL grind
and when u can get doin this good try downshifting with out a clutch
u have to hit the gas pedal while ur in neutral and let the rpm's rise and fall then it will pop in to a lower gear
Old Jan 26, 2002
Tetryl75's Avatar
Tetryl75 is an unknown quantity at this point
I've been driving like that for years in all of my cars, it shouldn't do any harm. The hard part is downshifting without using the clutch.
Old Jan 26, 2002
01civicboi's Avatar
so if we're moving and in gear (let's say 3rd ), i can shift into neutral without the cluctch, without harming anything?
Old Jan 28, 2002
ILLWILL's Avatar
ILLWILL is an unknown quantity at this point
i can shift while im driving
theres a trick to it u just ned to learn how to cat it at the right rpms
it works on any car
Old Feb 4, 2002
DoubleOSuk's Avatar
DoubleOSuk is an unknown quantity at this point
you can always pull your car out of gear w/o the clutch. and it isnt bad as long as you aren't giving it gas...in that case, the engine will just return to idle while you coast. if you do give it gas, the engine will rev obviously
Old Feb 4, 2002
01civicboi's Avatar
<< you can always pull your car out of gear w/o the clutch. and it isnt bad as long as you aren't giving it gas >>
that's exactly what i needed to know. thanks![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 18, 2002
HondaLuver's Avatar
Its a celebration bitches!
i never use a clutch, maby its because i have an automatic. haha. shotgun it...[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 18, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
<< I've been driving like that for years in all of my cars, it shouldn't do any harm. The hard part is downshifting without using the clutch. >>
Dats crazy man! Are your left foot is lazy or something Thats why they invented a so called clutch
Old Feb 19, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
yeah, i dont see the point of not using the clutch, youre just taking a big risk of grinding if you dont do it right, youre not really accomplishing anything
Old Feb 19, 2002
Bartkat's Avatar
If you learn how to do it right, you can improve your acceleration times. It's all a matter of technique. There is a certain amount of art to catching cogs.
Old Feb 28, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
yea dude all cars can shift out of gear with out the clutch.. even my old 93 ford tempo did(darn thing blew up on me)[IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/face-icon-small-cool.gif[/IMG]
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Jrosa
Sep 14, 2015 08:24 PM
