Clicking Noises 7k miles!
I have been hearing clicking noises from my 05 Civic EX w/ 7k miles. It happense everytime I turn (either way), go down a steep driveway ... what gives? Anyone else experiance this?
i dunno, probably something with your axles or something. if its under warranty (should be), just take it in and have them check it out
Bad news , I hit a pot whole in the road .. my tire flattened and now the car has a very loud popping/clicking noise when I turn. I'm going to call dealer on monday.
This should be covered by warranty right?
Touch it... He won't bite, He'll just come at you pretty quick.
Originally Posted by streetglower
my guess, you need new drive axles. Always indicated by popping noises when turning.
Originally Posted by Blahman240
cv joints... Drive axles don't make the clicking sound.
I had a clicking noise when turning right on my 02 EX Coupe. It turned out to be a transmission issue with the reverse idler gear and the 1st and 2nd gear syncros; there's a TSB for it (03-009). But that TSB was for 2001-2003 civics. Either way take it to the dealer and they should fix it.
I have a popping noise on my 01 lx coupe when turning the wheel from side to side but not just when moving like with cv axles. It does it really badly when pulling in or out of steep driveways. I found a tsb on alldata for bad compliance bushings in the lower front control arms. The car has 74k on it so warranty is out of the question. Is there anyone out there that has had a similar problem? I had a coworker turn the wheel and I listened to the strut, mount, and bearing with a stethascope and couldn't hear anything out of them, Also has anyone replace their bushings with polyurethane one and if so does the energy susp. kit come with both lower cont. arm bushings? Thanks ahead for any help.
Hey Rocket,
Did Honda ever fix this for you? I have the same exact noises, but I did not hit a pothole.
Thank you.
Thank you.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
nirvanaguy
25
Oct 26, 2017 07:26 PM
tommycanada
Sep 5, 2015 04:59 PM
