shaky steering at 70mph
Old Mar 16, 2005
TheJackBoot's Avatar
TheJackBoot is an unknown quantity at this point
my steering wheel shakes a lot when i hit 70 on the freeway, i have regular tires in good condition stock size so i dont think its that. Im not knoweldgeable in what goes on with the steering system so i dont know what could be causing it. anyone have this problem or know whats wrong? car is a 2001 civic coupe lx, no major modifications.
Old Mar 16, 2005
Logan3024's Avatar
have you balanced your rims and tires lately? Rims bents? Out of alignment? these are all things to check.
Old Mar 16, 2005
Pharoh's Avatar
Bobaganoosh!
usually a balancing problem occurs at around 120 km/h which is about 70 mph so that would be your first place to look.
if you live somewhere where it snows you may just have ice built up in the inside of the wheel causing a balance problem....this is why I don't get why people use hubcaps in the winter....they just trap **** between the cap and wheel...lame.
Old Mar 17, 2005
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
Certain tires when the thread are very worn out, it can also cause vibration at a certain speed.
Old Mar 17, 2005
thanks for the replies
Old Mar 18, 2005
flotsamm's Avatar
Rotate the tires front to back and test drive. If the problem goes away its a balance issue or bad tire.
Old Mar 18, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
I changed tires and oil for 4 years. you have an out of balance tire or a broken belt in a tire which would be indicated by a bubble sticking out of the tire....like a big pimple...ewwwwww. or you caught a curb turning one day or hit a pot hole too fast and bent a rim. its one of those things.
Old Mar 19, 2005
VP Stylee's Avatar
VP Stylee is an unknown quantity at this point
my front end was out of alignment and mine shook at about 55 and up but my front tires were worn too so tire rotation + alignment fixed mine now i can trap 70 with no shake
Old Mar 19, 2005
well the car doesnt veer to the right or left i dont think its out of alignment, and the tires look in good shape, and i have honda alloy wheels so i dont think i bent them they're only 14" wheels. how much is it to get alignment checked anyway?
Old Mar 19, 2005
hotrodcivic2004's Avatar
my civic has no boost
last time this happend ot me it was balancing issue. in fact all of my weights on my front wheels had flown off, so my tires were way out of balance.
Old Mar 21, 2005
ok thanks i didnt even think to check the balance weights since they're on the inside of the tire.
Old Mar 21, 2005
Jrfish007's Avatar
where you driving through snow or slush?
If you have alloy rims, the slush/snow can get on the inside of the rims, freeze on the inside and through the rim out of balance, it's happened to me many times this winter.
Old Mar 21, 2005
zachgeyer's Avatar
get it check out
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
