!!help peeps.. fuse keeps blowin
my left headlight fuse (in the fusebox) keeps blowin out? dont know why? I have hid's.... origianlly the fuse is 15amp i think... so i replaced it wit another 15amp fuse.. n it blew like a week later..., so i replaced it with a 20 amp fuse n it blew like 2 weeks later? wtf is going on... the rite side is still on its first 15amp fuse n never blew yet... wassup wit my left..can i just get like a 40amp fuse in there n jess hope it doesnt blow???
thanks
thanks
If you keep replacing the fuse then there is a problem. You really need to diagnose and fix the cause of the problem. Band-Aiding the problem with a higher rated fuse will shorten the life of your expensive HID ballast.
Most likely you have something putting out too many amps, or you have a loose ground or a short to ground somewhere.
Check for a short curcuit somewhere in the wiring. Look at the fuse and use the manual to tell u what the fuse is used for. Then when u find out what it protects go around the car and look at those components and see if theres a frayed wired hitting the car chassis or something. A short curcuit will cause ur fuse to blow.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
Klame9420
Sep 18, 2015 12:37 PM
Mc7602
Sep 17, 2015 02:01 PM
