car shakes at high speeds
Old Dec 3, 2004
fastcivic03's Avatar
fastcivic03 should not be trusted
Just noticed on a long trip over like 60 mph my car shakes like i feel it on the steering wheel shaking and once i get up to like 75 80 damn it shakes like no other, I just got an exhaust and new cat put on not too long ago, could it be the exhaust is loose or something? And I just recently had new brakes, tire rotation and wheel alignment done few weeks ago. What's the problem?
Old Dec 3, 2004
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
When my car does that it's because of the little bumps in the highway. Maybe it's your suspension getting older? Could it be your 18" rims and lowered suspension causing you to feel every single little bump in the road?
Old Dec 3, 2004
I had the same problem, but it went away when I got new tires to replace crappy firestones. Just the tire change fixed it, even before an alignment.
Old Dec 3, 2004
I've had the rims and suspension for about 9 months now, i dont have shocks could that be it? Nankang tires on 18s could be possible too??
Old Dec 3, 2004
nindoo's Avatar
Why is my vagina bleeding?
Could it be as simple as the tires needing to be balanced or the need for an alignment?
Old Dec 3, 2004
es2's Avatar
es2
bubble party!!!
es2 can only hope to improve
mine veers right
Old Dec 3, 2004
solar's Avatar
solar is an unknown quantity at this point
Take it back to the shop that did the work; sounds like they didn't balance them correctly, make sure they use a differnet tire balancer because some don't "spin up" fast enough. Its also possible that if they re-surfaced the rotors they might have gotten one or both of them out of round. That happens when the rotor isn't perfectly squared up on the brake lathe. I doubt thats the problem but I've seen first hand; it happens when the lathe operator gets a small piece of debris inside the rotor hub, and when the rotor is put on the lathe spindle its not perfectly squared up. Then the rotor is basically "re-surfaced out of round".
Old Dec 3, 2004
masarak's Avatar
Old Dec 3, 2004
Da1lyDr1ver's Avatar
do what SOLAR said and get your tires rebalanced.
Old Dec 3, 2004
shmik1's Avatar
I agree, sounds like a balancing problem
Old Dec 3, 2004
masarak's Avatar
How long has this shaking been going on? Was it happening before you got the brakes and wheels worked on?
Old Dec 3, 2004
Ya it was actually worse before the brakes and wheel adjustments and it got a little better. Just noticed this about 3 weeks ago when I took my car on the highway. Before it would shake at like 50 now it shakes over 60.
Old Dec 3, 2004
masarak's Avatar
Does it shake at all when you idle or at low speeds?
Old Dec 3, 2004
PunkingCivic's Avatar
I need TP for my bunghole
go get a 4 wheel alignment done.
Tha will solve the problem.
Old Dec 3, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Originally Posted by k2001civicboy
mine veers right
mine does the same when I shift really hard from 1st to 2nd, and sometimes 3rd.
Old Dec 3, 2004
es2's Avatar
es2
bubble party!!!
^^^lol
Old Dec 3, 2004
Sometimes it does shake at low speeds not till like 35-40mph but very little almost unnoticeable but once I go faster it gets worse
Old Dec 4, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
ditto. get your tires rebalanced and make sure your tires have correct PSI. Sometimes if you have uneven tire pressure, you will feel the shaking at moderate speed.
Old Dec 4, 2004
dalaw's Avatar
Bone Stock!
maybe there is a stone stuck on your tire tread.
Old Dec 4, 2004
MrDibbs19's Avatar
MrDibbs19 is an unknown quantity at this point
check your wheel allignment, i had the same problem a lil while ago, and somehow it was my front right wheel not alligned correctly, and brought it to a shop and fixed it, and its back to normal
Old Dec 8, 2004
solar's Avatar
Bad alignment will never cause a vibration, it's in the tires, hubs, rotors,drive axles, and wheels.
Old Jan 12, 2005
01civick20nme's Avatar
01civick20nme is an unknown quantity at this point
mine did that and i just got 2 new tires problem solved
Old Jan 13, 2005
yep i needed 1 new tire and got my tires balanced everything is fine now
Old Jan 15, 2005
Jeff B's Avatar
Jeff B has a little shameless behaviour in the past
Flat spots on the tire can cause vibration too.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
dooner24
Apr 14, 2015 07:51 PM
spoony
Nov 7, 2001 11:01 AM
