First Gear Won't Engage
Old Oct 31, 2004
CrazyCanuck's Avatar
CrazyCanuck is an unknown quantity at this point
I have a problem with my 03 EX Coupe 5-Speed.
1st gear won't engage once out of every 10 times or so. When I'm stopped, I change to 1st gear and I can't shift it all the way in. It stops about half way (seems to be when the gears would engage). If I can roll the car a bit with the clutch in it'll finally engage, otherwise I have to start in second.
It was never a smooth gear, always a little rough going in, but gradually getting worse.
Anyone see this before?
Old Oct 31, 2004
Mr.Modify's Avatar
happens to mine to.....prolly another honda defect.
Old Oct 31, 2004
Civic04's Avatar
Civic04 is an unknown quantity at this point
I have the same prob with reverse
Old Oct 31, 2004
dariusld's Avatar
dariusld is an unknown quantity at this point
Have you checked or changed your fluid lately?
Old Oct 31, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
When that happens, put the car into third, then try first again. Its almost like it has to be aligned.
Old Oct 31, 2004
Fluid is good.
The third to first trick does work, I think it is an alignment issue.
Hopefully one the dealer will fix.
Old Oct 31, 2004
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
let us know the progress after the dealer fix it.
Old Nov 1, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
i have the same problem and honda looked at me like if I was crazy? Im losing faith in honda itself
Old Nov 1, 2004
Atticus's Avatar
Atticus is an unknown quantity at this point
tranny defect for sure. service bulletin should cover it.
Old Nov 1, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
gears have teeth. sometimes the tip of the teeth hit another ...
just release the brake for a sec ... no biggie
Old Nov 2, 2004
VTECTypeR's Avatar
If it doesnt go to first gear i usually put it in reverse than back to first and it works good for me
Old Nov 3, 2004
tripledoublegs's Avatar
Euro-Spec
does happen to me every once in a while... not that much though
Old Nov 3, 2004
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
happens to me in reverse usually but not all the time.
Old Nov 7, 2004
Revmaster's Avatar
Revmaster is an unknown quantity at this point
It happens to me very seldom.
Try stepping on the clutch pedal a little harder then engage to 1st gear again.
If that wont work, depress the clutch fully then engage in 2nd gear and back to first gear.
That'll work for sure.
Old Nov 7, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
you know, in auto tranny, first gear not engaging means it gonne go soon. now in manual, not sure but im willing to bet that the tranny won't last past 105k w/o major work or some serious babying.
McLean
Jun 13, 2015 10:32 AM
jackshepardjr
May 24, 2015 09:53 PM
Ninetyatecivic
May 9, 2015 07:48 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
